Ride_the_lightning
- Jul 11, 2021
- Midwest
- Mach E Premium SR AWD
- Engineer
I meant turn connected services off for a few days to see if the problem clears up, then they can dig in more specifically to see what is causing the repeated polling. Turning it off permanently isn’t really a solution.That comment isn't factual, the DC/DC stays on as long as the ignition is ON regardless of door open. Voltage may change, but it stays on. Don't use accessory mode while tailgating to avoid 12V drain per the FAQ.
Have you used any 3rd party apps in the past that access vehicle data? Think hard. Here’s the list: Optiwatt, Recurrent, ev.energy, ABRP (OTA live data), Tronity, Charge Smart MA, SmartCharge Rewards, other power utility control/saver apps, FordPass plugins for HomeBridge or Home Assistant, phone widgets.
If so, you need to change your FordPass password to rule out polling.
I would not disable connected vehicle data completely, you won’t get OTAs and BlueCruise will stop working. Fix the root cause of the polling instead.
