240v charging suddenly not working?
ktgeek
Keith
Bartlett, IL
'10FusionHybrid,'18Expedition, RapidRed MME AWD eR
I am one of the many in Illinois who were hit with the "power is too dirty to charge" earlier in the year. Ford put out a patch and since then we've been happily charging on our hard wired in ChargePoint Home Flex.
On the morning of Dec 16th, my wife went to run an errand, came back, plugged in and it charged. That afternoon (and since then) when we plug in, we're getting "Plugged in, not charging" from the app. I can't find any obvious cause because nothing changed between the morning charge and afternoon charge.
2 questions for everyone:
1) What should I be looking at that I'm not thinking about and...
2) Anyone else seeing this? (Especially IL folks?)
That message can indicate several things, including that the ChargePoint HomeFlex isn't sending the car anything. Have you checked your ChargePoint app to ensure that it's set to provide charging during those hours and that it is ready to go?
Have you checked to see if your car is set to charge, that it's not confused that it's "at home"?
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
I don't suppose you have a NEMA 14-50 outlet you can test the Ford Mobile Charger with? That would at least rule out the charger instead of the car.
ktgeek
ktgeek
Keith
Bartlett, IL
It's on my list of things to do this weekend (should it still be going on.)
CHeil402
King of Prussia, PA
Electrical Engineer
Or maybe Illinois one-upped Ford and made their power even more dirty ?
I would suggest you, or the Electrician that installed your outlet/charger, check torque on all connections to make sure everything is tight.
ktgeek
ktgeek
Keith
Bartlett, IL
There was a windstorm 2 days ago that is making me worried about that...
Yep, both of those are good. The ChargePoint isn't showing any errors and is all blue like its connected.
I didn't think about it not thinking about it being home, but looking at Charging location, the mustang is showing my home address.
ktgeek
ktgeek
Keith
Bartlett, IL
We did have a pretty serious windstorm, I could see ComEd doing repairs mucking up the power.
Carsinmyblood
Mitch
Western NC
Self employed
When I moved into my house there was a buzzing sound coming from inside the panel. One of the grub screws on one of the main feed cables was loose and buzzing.
Yes, electrical connections can come loose.
ARK
Los Angeles
'21 Premium SR AWD
Something similar happened to me too, a pair of wires in some random outlet hadn’t been tied all that well when the electrician worked on it. Over a year later, half the house suddenly lost power. Took the electrician hours to move through the house checking each outlet before they saw it, figured out what it was, and simply tightened the connection.
It would be a good idea to check ALL terminal lugs and circuit breaker lugs when they have the deadfront off.... loose connections can cause arcing; 'dirty power', and fires.
ktgeek
ktgeek
Keith
Bartlett, IL
Thank you to everyone who said "check the electrical connections." Guess I know one of my weekend projects.
one of the biggest 'dangers' of DIY or non-permitted/inspected Electrical work is loose connections... especially in circuits that carry heavy current for hours at a time and heat up and then cool down.
EV charge circuits, and Solar PV backfeed circuits are important to check once in a while even if installed by a professional.
Glen
Glenn
I had my Charge Point installation inspected and approved today by the township. NOW if I only had the car. Lol..?
I would never do my own electrical work. I just dont have the knack for it.
D4rkt
Paul
Melbourne, FL
2013 Ford Escape, 2021 MME Premium ER
