And so it begins...
While I agree with this in a perfect world, my real life experience is such that those chargers are so unreliable, I'll connect to any one that happens to be working - if it maxes out my charge rate, even better!
I've found EVGo chargers to be pretty reliable (unlike EA).
dj_stang
{None}
2022 MME Premium -> 2023 GTPE
I would like to see DCFC stations at least “strongly recommend” if not enforce charging at a specific stall determined by a simple algorithm that optimizes everyone’s charging speed. A rudimentary one is charge at the minimum kW station that is at or near the car’s maximum kW draw.
Sadly the knuckleheads at EA can’t even implement idle fees properly so it’s doubtful this will come to fruition. Tesla would do it but they have so many high power stalls that it wouldn’t make a difference.
The new EA stations use load balancing so anyone can charge at any working station (except the CHAdeMO stall).
I hit 161 often. This past Saturday.
67 Stang Convertible
Rich
Georgia, USA
Physician
Yes, but for how long? That is the real issue with DCFC. It's not the peak of the curve, I've hit 160kw at an EA station, it's the longevity of the curve staying high that is important.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
This has been floating around Reddit for some time now. @breeves002 x-posted it as well on Reddit.
Personally, I have no idea where this idea of entitlement comes from that many people are claiming about the sign creator. It's about respect for others, not entitlement. The only people espousing entitlement are those selfish enough to think they shouldn't respect or be courteous to others by taking a unit way beyond their charging capacity when lower capacity units are available.
If you plug in a VW E-Golf to a 350kW unit that maxes at 50kW (when lower power units are available), that's just flat out rude and selfish (or uneducated - which is what the sign addresses). It's not the same as a gas pump as some others claim. Gas pumps are all the same, EV chargers are not.
So, I guess I'm an entitled prick (no surprise to many here) because I say if you own a Chevrolet Bolt EV/EUV, Hyundai Kona Electric, Nissan Leaf, Mazda MX-30, Mini Cooper SE, Smart EQ Fortwo, Volkswagen e-GOlf, Ford Transit EV etc you should first go for a 50kW and then a 150kW and then if none of those are open a 350kW.
If you own a MachE, you should look for a 150kW first and then if none are available a 350kW. For those of you who say "But we max the MME at 160kW and therefore we should use the 350kW", no stop being a selfish ass hat because you only save 25.2 seconds in an entire charge. I did the tests to prove it (here).
There's also a whole thing about chargers and their stated output capacities in the link above that I would recommend reading for those who don't understand how these chargers work. For the sake of this post the 50/150/350 units I referenced above would be using EA stations.
Here's the sign in question btw:
1000% agree. The complete lack of education around BEV charging is one of the things holding back adoption. That combined with the proliferation of myths. BEVs are cool and good for the planet. Sadly the people that own them, if asshats before, will remain asshats afterwards.
Guss-E 2021
Pierre
New Hampshire
Not gonna lie, I never gave it any thought until reading this post. I suspect others don't give it any thought when pulling up to a charger. I will be more aware now.
This goes back to education. At the point of purchase the buyer should be made aware of the charging curve. "Now this car has a max charge rate of X, so don't bother plugging in to a faster station. Yes they are labeled". I'm sure I'm giving way to much credit to car sales people. The only gem of wisdom I've heard from a sales person in regards to the MME is "it's really fast!" ?
SWO
MD, USA
I would be curious if the average EV owner knows how much their car maxs out at.
My guess is that most don't. And assume that the charger alone controls how much power their cars get.
Agree. I stopped at an EA in South Carolina on a trip. Checked plugshare enroute and it said that Charger 2 was throttled to 32kw. I pull up and there's one car charging - a Mercedes EQS....plugged into Charger 2. The owner (an older woman) was sleeping inside as the charger plodded along at 32kw. Most people are oblivious.
SWO
MD, USA
The ER Mach-E's will charge at least 10kw faster throughout the charging curve at an EA 350kw vs 150kw in my experience. It's appreciably faster. If I recall correctly, the Mach-e maxes out the amperage on the 150's.
SWO
MD, USA
It's not just the kw rating. A great example are the EvGo 200kw chargers. A Mach-E won't get over 80kw on one because they are amp limited. The EA 150kw chargers have the same problem, though to a lesser extent.
PharaohHound138
2022 Mach-E premium
Railroad
Looks like EVs have hit a critical point now where we're turning on each other.
EVs icing other EVs....
https://jalopnik.com/bizarre-passive-aggressive-notes-for-drivers-of-evs-wi-1850894124
I didn’t really get too butt hurt about that letter. It seemed more like trying to spread some awareness until the phrase “ educate yourself” came into play. That phrase is just a way of calling people stupid yet having deniability that you called them stupid! IMO. Once that phrase was added, I would’ve just taking the note down
Corsair234
Jon
Washington, DC
Volvo XC60
Attorney
I think this whole discussion is useful, but the real problem in my experience is not folks using the wrong charger, it's using DCFC to get to >90%. No one seems to realize (or care) that their charge rate plummets as the battery fills. That's all well and good when there's no one waiting, but sitting for half an hour on a road trip while someone goes from 80% to 95% is maddening.
Jack Roberts
Atlanta
Mach e GT
jeffMachE
Jeff
Colorado
F-350, '21 Prem 4EX, '24 Lyriq
IMHO (flame suit on), this is a temporary issue that in 18-24 months (not a long time realistically) this will go away. The number of slow charging EV's is pretty small, and the percentage of those vehicles on the road is dropping every month. New stations are high-output and older stations that are 150 KW or less will become the minority. But for the next year or two, there will be a lot contention.
My view is that we are ping-ponging between a low ratio of EVs to Chargers and a high-ratio of EVs to chargers. A few years back, it was relatively easy to find a charger (low ratio), today its hard (high ratio). But Chargers are going to come on line more quickly than EV's over the next couple of years putting us back in a low ratio. Then EV's will sell more quickly and we'll move to a high ratio. But each time, the overall problem gets a little better.
