kodiakng
- David
- Oct 1, 2022
- Oregon
- 2023 Cyber Orange 4X Mach-E
are you using the same login credentials in fordpass as for the widget? if you are, and your fordpass app is working correctly, your account probably isn't locked and you might just need to re-login in the widget app.OK I know the answer is somewhere in this loooong thread... but maybe a simple Q / A is a better path. I love this widget, yet it recently lost its ability to get data from the FordPass app.
How to get the widget to re-engage? Thanks in advance.
if you aren't using the same login credentials you might check if that account is locked by logging in through the web portal. if it isn't locked you may just need to re-login in the widget app.
if your account is locked you'll need to contact ford to have it unlocked.
