- Greg
- Apr 20, 2020
- Phoenix
- 2021 Mach-E FE, 2021 Wrangler 4xe High Altitude
- Manager
I agree with this post.For the Focus Electric (FFE) Ford always published the entire size of the battery. What was useable was figured out by owner's once they started driving it.
One way was a run down test: The FFE has an enhanced trip meter showing kWh consumed. You would charge to full, reset the trip meter, and turn it on with the HVAC set to full defrost...let it sit there until the battery was fully discharged--the kWh reading on the trip meter would show you how much of the battery was useable.
The other way, once Forescan added FFE support, was simply to read the value off the OBD-II bus.
My FFE had the smaller battery at 23kWh and only used about 17-18kWh of it.
I think at this stage you're looking at engineers and salespeople just giving you rounded amounts and not specific values. Thus I don't think the 5kWh and 8kWh are buffer's of any sort--just a mental rounding error. It won't be until people start driving the vehicle before we really find out and even then a simple software change could change the ratios.
From past experience (and even on the hybrids, "Energi" models) Ford has always published the total size of the battery so I would be pretty confident in saying that their targets are 75kWh and 98kWh for the total battery overall; we'll just have to wait to see what or if there is any buffering...
Past practice says that Ford publishes the physical battery capacity but they could change to "usable capacity" at any time I suppose. My guess is the Mach e might average around 295-300 wh/mile based on the published range estimates. This calculates to about 68.5-69kwh of useable battery which is maybe a little high so maybe an average of 275wh/mile is closer to reality.
Again, we will know a lot more about this once these are available to the public. Looking forward to it.
