Charge rate gone from fordpass
Skip Towne
New Hampshire
Mach-E 4x Premium
I welcomed the recnt fordpass upgrade 4.25 and the view of the charge rate while charging.
Today, I notice, it is not visible.
Any idea why or what I did to make it go away?
The visible charge rate was actually useful, as opposed to the word-salad of time on charger and expected finish time
Skip Towne
New Hampshire
Mach-E 4x Premium
Ford Mustang Mach-E Charge rate gone from fordpass Screenshot_20230404-180946_FordPass
MG101
RI
a car
I've noticed if it reaches the target charge then I hit charge to 100% it will no longer show the charge rate.
Vulnox
Livonia, MI
Even if mine stops it shows how much was added and has a placeholder for charge rate. Not sure why OP doesn’t even have that. Unless it is due to what is said above. But I guess I suspected OP would have mentioned they did something different like select to charge to 100.
Ford Mustang Mach-E Charge rate gone from fordpass IMG_0629
mateo
2022 MME GT
I have two MMEs. It used to show up on both. (For the brief time it was supported.) Now it only shows up for one of them. Tomorrow it probably won't show up on either.
When mine is done charging, it shows 2 dashes in the field.
Skip Towne
New Hampshire
Mach-E 4x Premium
Mystery solved!
I think the issue is as you guessed - I was charging past the set point to 100% when the charge rate wasn't being displayed. I didn't mention that in the OP, not imagining the charging target would impact whether the charge rate would be displayed.
I just drove 150 miles (so now well below the target charge point) and plugged in - and viola, the charge rate shows up again!
There is a lot to like about the Mach E and even Fordpass. The on-again off-again features are not one of them.
Thanks to all for the help
Mathington
Canada
Mach-E Premium SR AWD
I noticed this issue as well, I am not seeing the charging speed when I clicked “charge to 100%” in the FP app.
