JohnFoxeSheets
- John
- Jan 29, 2022
- San Francisco
- Website
- johnfoxesheets.com
- 2022 Iced Blue Silver Mach E GT
- Retired Engineer
The 12V battery is only maintained while the high voltage battery is actively charging. Once charging is finished, the car goes to sleep and the 12V battery may drain dead even though it is still plugged in. I’ll have to look later what’s going on, but could be a charge fault or just a bad 12V battery.
Hmm, my understanding is as per what @Richard L. wrote. What you're saying Lee appears to be different...?I have posted this before in other threads. Below is the charging strategy for the Mach E. The 12V battery will always charge when needed. If repeated charging is required as a result of some external drain, battery damage will occur.
Taken from Ford Special Vehicle Engineering:
While ignition is off, if 12V battery reaches 40% state of charge, then vehicle waits 48 hours , before the DC-DC transfers 300 Watt-hours of energy to recharge the 12V battery. The HV power comes from either HV battery or wall power while on plug. If the 12V battery state of charge reaches 30%, then this HV to LV energy transfer happens immediately with no delay.
Note:
• This system was designed to recharge 12V battery while the vehicle was left parked for many days
either on or off plug or occasional drain from customer usage. The 12V battery will wear out if this energy transfer is completed daily due to aftermarket loads draining the 12V battery down to 40% or lower.
• Vehicle has 35 Amp-hour AGM 12V Battery
