g8mb1t
Godalming, United Kingdom
24 MME Premium AWD ER, former keeper of 21 MME First Edition
when I did the update on Friday, I did notice the range increased slightly @80% charge before its was 189 and the estimated ended up at 222 after the update, haven’t tied DC fast charging but wish they recorded the charing curve in the app
ProximusAl
UK
Mach-E - SR-AWD - Star White
Mine also did this but I put it down to the EV driving history being reset as part of the updates. It’s done it to me before on previous updates.
Mockingbird2004
California USA
2021 Mach E GT
Elevator Construction Mechanic
Send me your VIN and I can look if you want.
Though if they updated the BECM it should have forced them to update the PCM, SOBDM, SOBDMB/C as well. Maybe not though. I always start with the PCM and it forces you to update the rest.
I put my GT vin in not my FE which is why it didn't show up. It is showing up for the FE.
3FMTK4SX8MMD99649
DevSecOps
Todd
CISO
For the 50 or so people who I ran a VIN for that couldn't get the dealership to update because there wasn't a reason to ... well here's your reason. Go tell them to update it now as long as your MME falls within the build dates in the memo.
Along with this update, there are several additional updates for customer satisfaction included in this
software update. This will include updates for no start, handling performance, ability for over the air
updates, improved range in cold weather, DC fast charge total time improvements, display range
accuracy, e-latch door robustness, and phone as a key detection.”
How can software change “handling performance” and “e-latch door robustness?”
I'll try and figure out a way to keep my car away from the dealership until I hit 36,000 miles that way they won't be tempted to install any software. I'll see if I can get Safelite to replace my windshield instead of having the dealership do it....
Seems the primary issue to resolve here is that downhill regen for extended distances. I don't think I encounter that very often. I've been through the mountains here a few times and so far so good. Would like to avoid this issue if possible but I don't want them opening up any of my battery capacity or speeding up the DC fast charging or anything like that so I'll sit this one out for now.
The secondary notes are interesting. "there are several additional updates for customer satisfaction included....."
  1. No Start
  2. Handling Performance
  3. ability for OTA
  4. Improved range in cold weather
  5. DC fast charge total time improvements
  6. display range accuracy
  7. e-latch door robustness
  8. PaaK detection.
Affected vehicle built thru June 18, 2021. So that means only Premiums, Selects and CR1 then?
#2 is interesting and something discussed in another thread. There are software calibrations that impact handling performance? The WSM does say the ABS system affects handling somehow. Kinda interesting.
Besides fixing the downhill shutdown issue, none of the 8 items listed matter to me. At least, not enough to want to change anything. Items #1-#7 work fine for me so far and #8 is not applicable.
Apparently the handling performance is affected by the software. I mentioned this in another thread but I don't remember the topic. I found some language in the workshop manual that describes the different drive modes and how handling is different in each mode and it didn't seem to reference the GTPE at all. In fact, the WSM doesn't really address the GTPE specific items until you enter a GTPE VIN and the you get to see the other stuff like front motor specifics, different cooling lines, etc.
Then somewhere else in the manual it talks about the ABS and brake system affecting handling in some way. It sounded a little like virtual torque vectoring (if that makes any sense....) ?? ?
First one could have to do with failing the moose test, second one could have to do with the doors sometimes opening when locked.
Gullwingdmc
Chip
Boston, MA
Excuse my ignorance on this, but this update pack will not include the 1.7.1 update right? I didn’t see the APIM module listed in the letter. Just wondering if I should ask for this update and 1.7.1 when I bring my car in next month for its 10k service.
Correct, the APIM 1.7.1 update is not included in this CSP.
rhougey
Rich
North California
"Improved range in cold weather"? Wonder what that is about
I believe mine will qualify for this CSP, as I have a build date of 2/1/21. Already past one third of the way to 36K miles. Two specific things I hope it affects:
1) I have noticed a dramatic reduction in range in temps below 50 degrees (F) as compared to summer when temps were in the 80's, 90's and 100's. I expected less range with colder temps, but at 50F it has been more dramatic than anticipated.
2) I haven't seen any other complaints about this, but at 70 mph on winding mountain roads with Adaptive Cruise on, the car cuts speed slightly when steering wheel input reaches a certain angle until you straighten back out, as if the car thinks I'm going too fast for the curve.
IMDIDOC
Alex
Buffalo NY
2021 Mach-E FE
Optometrist
I have never in 6 months received an OTA update, so I hope this fixes that. No 1.7.2 for me. I asked the service tech and he reports dealers can't do those.
The steering is electric, so it is possible to change that as Engaged plays with that too.
I also have the clicking noise on hard left turns. I wondering if it doesn't have something to do with a lack of a conventional differential.
kltye
IB MME Premium RWD
Guys, I performed the update and I'm happy to announce that the charging cliff at 80% for DCFC has been improved! Between 28-30kW! Screenshot of EA station and Car Scanner stats.
Ford Mustang Mach-E Customer Satisfaction Program 21P22 - Software Calibration Update 20211123_184713.JPG
Ford Mustang Mach-E Customer Satisfaction Program 21P22 - Software Calibration Update Screenshot_20211123-184746
Edit: the battery may have been cold gating. Power going in has increased to 40kW, battery temp is 66F now.
BalsaDust
Tony
Delaware
This, that, and everything
The MME has a differential in both the front and rear drive trains. I remember seeing them disassembled in the Munro teardown videos.
Tony
Ah, could be stability control settings.
The “robustness” just throws me off a little on the door latch description.
Ford always seems to give just enough information to confuse people. Would it really be that hard to write a couple sentence description?
