DIY - Mounting Escort Radar - Mag Mount Specific
DevSecOps
Todd
CISO
I've commented in a few other threads about different Radar Detector Mounts. I previously mounted a less expensive model and posted those. This is a detailed install of the Mag Mount devices which are for specific to Escort models Escort IX, Escort IXc, Max 360c, Redline EX, MAX 3 Redline 360c, and MAX 360 newer (2019 and later).
For the older style which has the metal that slides into the detector you can see how I mounted that here.
Reason We Need A Mount Solution?
The windshield of the MME is specifically designed to block IR which also interferes with radar detection, known as IRR (Infrared Reflection). The only area of the windshield that doesn't have IRR is where the black dots exist around the rear view mirror. For anyone with "FasTrak" or other transponder these need to be placed in the black dot area as well in order to work properly.
The position on the black dots relative to the headliner present a challenge for mounting. This is why people have struggled with mounting options.
Do Radar Detectors Even Work?
In almost all of the threads about radar detectors, someone has to chime in and say "just slow down" or "those things don't even work". Please be mindful that not everyone want's to slow down. If it were I, I would tell you to speed up or move over. We all drive differently, stay out of my way and I'll stay out of yours! I don't care if you want to drive under the limit, just do it behind some 18 wheeler (you can draft that way).
Do they work? Most definitely! I'm in California where I disable X and K bands all together. Only on Federal land do they use those in CA. All other radar in CA is either KA Band or Laser/LIDAR. This eliminates all of the false alarms caused by door openers etc.
What about the cop on the side of the road using LIDAR? Well if he shoots that thing at you, you're toast! These detectors aren't for those situations, however I have noticed that many of those officers will leave their radar on and that's a dead giveaway to detectors. You still have to be aware of your surroundings. Most of the time if there is a cop on the side of the road, he's also on Waze ...
Don't they just turn the radar on and off? Well yeah they do, but when he turned it on for the car, 10 cars ahead of you, you should have been warned.
In summary, radar detectors are a tool, one of many, that make me feel more comfortable driving. Escort will even pay for your speeding ticket if you get one, so the investment doesn't go to waste.
Now on to the Mount:
The first thing that I did was to take the handle to the mag mount and remove it from the suction cup plunger so to remove the plunger from the actual mount. Then unscrew the bolt and remove the magnet, screw, nut and washer from the base.
Once that is complete, take a hack saw and cut the mount along the top of the ridges that lead down to the bolt holes. It should look like this when done:
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_013002716
Once it's cut you'll notice that the radius is grooved. This will cause issues with the VHB tape and result in failure of the bond to the window. In order to fix this we'll fill the radius groves and the half-moon cup with epoxy. I used JB Weld plastic to plastic epoxy, which you can get at Home Depot. Rough up the inside of the cup a little, place wax paper on the edge as a mold and put it in a vise.
NOTE: if you don't have a vise, fill the entire cup with epoxy and then cut after. You'll just be wasting epoxy, but you could reverse those steps in that situation.
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211022_212150205
Once the epoxy is in place you'll want to use a straight edge to remove the overflow but be careful not to create a void or dip in the epoxy. You want it slightly higher than the plastic.
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211022_212305338
Now with some 1000 grit wet sandpaper, sand it down until the epoxy is no longer on the plastic and is level to the plastic.
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211023_031618276
Once that is done clean the underside of the plastic with rubbing alcohol to remove any contaminants.
Now apply some 3M VHB tape to the underside of the mount. It should touch the radius and the support arms as shown below:
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_013319764
Get an knife and form the VHB to the plastic so that we don't have a sticky fly trap in the window. Don't do this on the counter otherwise you might have a significant other that will make you sleep in the car.
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_013734306
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_013740676
Reattach the bolt, nut and washer to the base. Then let's go to the car and attach the base to the detector for placement.
With the VHB tape still having the protective film on it, find a place where this mount can go all the way to the headliner. Position it how you want it. Then clean the window with some rubbing alcohol and let it dry.
Remove the protective film from the tape and place the mount where you previously aligned it to.
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_014401915
Let the VHB tape do it's thing for 24-72 hours. 3M says 72 hours for a full hold whereas 24 hours is supposed to be 90%.
Once the VHB has "bonded" attach your detector and off you go!
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_014532633
Ford Mustang Mach-E DIY - Mounting Escort Radar - Mag Mount Specific PXL_20211020_014558462
OPTION #2 -
Buy a custom mount. See my post here: https://www.macheforum.com/site/thr...rt-radar-mag-mount-specific.10559/post-401173
Fat Mach
Nor Cal
2013 GT350
Great how-to. Which detector did you go with? I have a coupler 20 year old Beltech's or something like that and I'd like to use something that can be configured to only report KA band as well.
DevSecOps
DevSecOps
Todd
CISO
I have the redline 360c in this car and a Max 360c in my Audi. I like both because of connected car, social reporting features.
Fat Mach
Nor Cal
2013 GT350
Thanks!
Fat Mach
Nor Cal
2013 GT350
Did you just break off the handle with pliers or something to remove the plunger?
Also, are you powering it from the mirror, or did you just plug it in?
DevSecOps
DevSecOps
Todd
CISO
The plunger handle clips to the piece that goes through to the rubber. It really doesn't matter how you remove it since it's trash after anyway.
I powered it directly to the fuses. There's many reasons I don't like tapping into existing electrical. Here's the thread where I ran the wiring: https://www.macheforum.com/site/thr...a-dashcam-and-radar-detector.5542/post-262345
Doing a mirror tap, has in the past, cost me thousands of dollars in diagnostic issues for monitored electrical systems in a previous Audi. Additionally, if you attempt to sell the vehicle removing a fuse tap is simple and easy essentially making it unmodified. Tuck the RJ3 into the headliner, remove the tap and no one knows.
Fat Mach
Nor Cal
2013 GT350
Doing a mirror tap, has in the past cost, cost me thousands of dollars in diagnostic issues for monitored electrical systems in a previous Audi. Additionally, if you attempt to sell the vehicle removing a fuse tap is simple and easy essentially making it unmodified. Tuck the RJ3 into the headliner, remove the tap and no one knows.
Thanks! I like to run dedicated wires as well. In my truck I put a painless auxiliary fuse block with flying leads, and a nice ground bus bar to power my devices.
DevSecOps
DevSecOps
Todd
CISO
The interior fuse box on the MME has a bunch of unused sockets so it's really easy to connect to them. There's also plenty of clean metal to grab a ground in the same area. It's a really easy fuse box to work with compared to some I've had.
harrysiii
Harry
New Hampshire
2025 Ford Bronco Badlands Sas, 2025 Toyota Grand Highlander Hybrid MAX Platinum
Do you run the direct wire with the remote Smart Wire, or will a Mirror Tap wire work for this particular Redline 360c?
DevSecOps
DevSecOps
Todd
CISO
harrysiii
Harry
New Hampshire
DevSecOps
DevSecOps
Todd
CISO
I've been using Mirror Tap for many years now; care to elaborate?
I've been in heated arguments with people over this before one of them was actually banned from the forum because he got that animated over the subject.
Let me say that if you want to go to a mirror tap, then do it. To each their own and it's your car, your money and your time. Years ago I tapped into the wires in my Audi in the upper console. All was well until I started experiencing issues with the backup camera and the radio malfunctioning. I didn't tap into anything to do with the radio or the backup camera, but those started experiencing issues.
Audi had the car for weeks trying to figure out why. Eventually after Audi corporate was involved they determined it was because of the extra draw, mostly at startup, of the detector that was causing the issue. The bill actually came to over 5k, but since I purchased over 10 Audi's from that dealer they went ahead and lowered the price to cost without markup and I walked away with my head down and a hole in my pocket.
A side note, Chevrolet has actually put out a TSB for the 2021 Corvettes ( Bulletin #21-NA-251 ) where mirror taps have been causing excessive voltage and frying the components in the outer mirrors.
The safest thing you can do is go to the fuse box. The MME has a ton of open spots and there's no reason to risk tapping in my humble opinion. When going direct to the fuse box the only concern is the line size from the battery to the box, but in the MME it's oversized and the draw from the detector will not have negative consequences.
harrysiii
Harry
New Hampshire
Great info. Thank you. I had no idea.
harrysiii
Harry
New Hampshire
Thank you! I took your method and modified my mount the same way. Perfect!
FarSide
Fairfield, CT
Jaguar F-Type '70 Vet, Outback Onyx, '04 Wrangler
Thank you for this great thread.
Does anyone know if the 2022 models have IR blocking issues due to metallic tints or athermic glass? I know that there is different glass being used in the car now due to supply change problems and perhaps the post windshield recall have changed things? I would like to avoid mounting the RD up by the dotted cut-outs.?
