E Heat Question
derill03420
Derick
2021 mach e select AWD std range
Electrical Engineer
So I found the e heat button today and it seems that if e heat is turned off the air coming out of vents is just cold. Am I missing something? I know Mach e does not have heat pump but just want to be sure I’m not missing something.
Nope, you're not missing anything. If you turn off e-heat, you won't get any heat.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
With out e-heat. There is no heat. There is only Zuul.
Motomax
Max
VW GLI, 4Runner
In this case E heat means electric heat and not emergency heat or secondary heat that it usually means in the hvac world.
they Should have just called it “HEAT”.
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
Without e-heat would I be correct in assuming the only heat would be that which is produced by the battery system or are the two completely different coolant loops and not shared?
RTFM:
Switching the Electric Heater On and Off
When E-Heat is on, an electric heater is used to warm the cabin and keep the windows from fogging. Turning E-Heat off saves battery power, which extends your driving range.
The electric heater is the only source of heat to warm the cabin.
Cabin and battery share a loop, but lithium batteries don't generate much heat unless they are charging. While driving E-heat is the only source of heat.
JimmyMachE
Montana
Mach E
The motor, inverter and electronic units generate heat. But not sure if that would have or has any noticeable impact on cabin heating.
zvez
chris
ga
I've had this car six months I didn't notice the E-heat button til I read this, I've just always used the auto mode.
Just keep doing that and you'll be fine. I'm amazed at the number of people that manually turn off e-heat and then complain that they get no heat. That's like turning off your TV and then complaining that you can't see your show anymore.
