EZ-Pass transponder interference?
Mirak
Kansas
Yeah its hard to see, but around where that blue arrow is pointing you can faintly see a line all the way across where its a little darker at the bottom.
And yes, The top is where I have the new sticker, And below the black is where I put it originally and haven't fully cleaned it off. This was where I had put it on all my other vehicles so It was my go-to spot.
Ok that's super helpful thanks.
Pbaran
Paul
Palm Coast, Fl
2017 Escape, 2006 Ranger
Ford Mustang Mach-E EZ-Pass transponder interference? signal-2021-02-25-093224
The above 2 transponders work. At first I had them reversed and the adhesive front gate transponder would not work on the bottom position.
RoadRower
Lauren
Ford Mach-E Premium 2021
Anyone in the SF Bay Area try their Fastrak to see if it works with the windshield? I'm happy to test but if someone else has done it before me, that's great too!
I tossed it on the dash in middle 'dent' area and that sure didn't work!
medicnj
Pete
new jersey
Ford Edge, Ford Mach E Star White
EMT
I put my E-ZPass on the grated area of the windshield next to the mirror. The slow lanes register it but I don't think high speed does. I was charged full rate on my tolls. I don't have plates on yet as it's still new and being transferred. NY EZ does not look to offer exterior tags. What about sticking it to the front corner of the sunroof?
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
This is my solution to the carwash tag that won't work through the windshield. Their sensors are pointed in a way they can only read if the tag is in the very bottom corner of the windshield. So even in the black dotted area it wouldn't read it.
As I pull up, roll the window down stick this out and it works. Keep it up in the sun visor in the card holder. I wouldn't want to use this for toll tags though. This is only really a solution for like a gate reader or something you don't use often.
I just happened to have a piece of plastic from something I bought on amazon on the counter, cut it down and stuck it on. Made it big enough I could add others if I ever need to.
Ford Mustang Mach-E EZ-Pass transponder interference? 20210414_101035
benk016
Tulsa, Oklahoma
How did you mount it in that area? The other users tag seemed to be mounted a little high. If you only have the one, I'd make sure its in the very center of that area.
I've had my tag in this area for a while now and it hasn't missed a single toll yet, even at 85mph.
medicnj
Pete
new jersey
EMT
Do you have high speed toll lanes?
medicnj
Pete
new jersey
EMT
On the slow lanes where you go down to 5mph they see it, just thinking the ones high up that you do 50-70 mph through....
benk016
Tulsa, Oklahoma
dml105
Arlington, VA
I mounted mine in the black mesh next to the rear view mirror with command strips. Here’s the problem: that gets hot in the sun, and the adhesive fails. I’m going to need to find a new way to mount mine.
GoGoGadgetMachE
get a suction cup pouch or holder of the right size. works well for my transponder and the gf's transponder.
back_at_it_19
Seattle area
This is the adhesive you need. Also at Lowe’s or Home Depot I think. It’s what our DOT provides with the pass. Works great. EZ Pass/I-Pass/SunPass Adhesive Strips https://www.amazon.com/dp/B007BH5848/ref=cm_sw_r_sms_api_glt_fabc_MGSH1X73MDER4AQXQXBQ
