Ford Power-up 4.2.6
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
@JoeDimwit not seeing how you can change the amperage in the app. Any direction?
That’s the crappy part… you have to delete the unit, then when you re-add it you tell it it’s connected to a smaller circuit breaker. In my case, since I wanted 32 amps max, I told it it was on a 40A breaker. If I needed to drop down to 24A, I’d tell it it was a 30A breaker.
Download the ChargePoint Service Pro app. That will let you change the amperage without having to set it up again.
JoeDimwit
Waterford
Electrician
Damnit!!! I wish I had known that before resetting mine the old way… I still have to mess with my WiFi to get my unit to reconnect.
adamtstipp
Missouri
2024 EV9 LLR, 2022 Mustang Mach-e Premium
I got this update yesterday. Braking is definitely smoother when coming to a complete stop with 1PD.
The direction to try it came from someone I trust due to their job, and it does seem to be working. It
Cool. I wonder what throttling charging has to do with it though.
Gullwingdmc
Chip
Boston, MA
Installed!
Ford Mustang Mach-E Ford Power-up 4.2.6 IMG_5580
I checked my 12v battery level before the instal last night just to be sure.
What has everyone been seeing for range post update? Is it more or less realistic?
Also what did the do to the charge port connection?
“We've made updates to your charge port connection.”
Eric_C_Boston
Eric
North Shore, MA, USA
Retired Software Engineer
I had a failed 4.2.6 update over night a couple of days ago. The next day I made sure the 12 volt battery was topped up and tried update now. It was successful. I updated the SOBDMA module in December via FDRS so that module was up-to-date.
Code:
ABS
DA01  LK9C-2C219-CD  -> LK9C-2C219-CK
F188  LK9C-2D053-CD  -> LK9C-2D053-CK
F10A  LK9C-14C602-DH -> LK9C-14C602-DS
PCM
DA01  MJ98-12A650-BDN -> MJ98-12A650-BDP
F188  MJ98-14C204-BDN -> MJ98-14C204-BDP
BECM
DA01  NJ98-10B687-BE -> NJ98-10B687-BH
F188  NJ98-14C197-BE -> NJ98-14C197-BH
SOBDMC
DA01  NJ98-7P120-SD  -> NJ98-7P120-SF
F188  NJ98-14G069-SD -> NJ98-14G069-SF
Atxsw
Austin
Just got this tonight, which is odd since i have never gotten an update on the weekend
RSH
RSH
2021 MME Rapid Red Premium ER
4.2.6 has tried to install nearly a dozen times. Every everyday scenario imaginable. Plugged in to the home charger, not plugged in, driven for an hour beforehand, scheduled initiation, manual initiation... It always fails. Absolutely maddening.
Now I'm wondering if the fact that the charge port was replaced (under warranty) has something to do with the 4.2.6 install fail.
Mine failed several times as well, and I also had tried all the things you and @ZombieJester mentioned. Based on a post by @Mach-Lee I set it to charge for at least three hours and changed my update schedule to update one hour after the charge should have been completed. It worked! Woke up to an updated car.
Dooger54
Doug
Tucson AZ
2023 Mach E Premium
Newbie here. Mine just updated May 16 to 4.2.2. How long does it take to get updates? Are they done in stages?
AKgrampy
Fairbanks, Alaska
There is no set time but I will say that after sitting for 6 months with no updates that once I received the first 4.2.X then they all came in within a couple of weeks except this latest one which appears to be out for EA at this time.
agoldman
Charleston, SC
That app asked me only what the circuit was. I answered the fact it was 50 amps. So does that mean they think 50 amps is safe and sets it there?
