FordPass 4.23.1 just released
Jimmy2
Jimmy
Wilmington NC
Excellent, it will come in handy for those cold winter days upon us.
hbirring01
Baltimore, MD
2021 Ford Mustang Mach-E, 2025 Rivian R1s, 2021 Tesla Model 3
Surprisingly the departure times worked on 4.23.0 for me 2 days ago. Thinking it was server side
Johnny B
Chandler, AZ
2021 Mach E Premium RWD 2017Nissan Titan XD Diesel
Retired Software Developer
Was not working for me with 4.23.0. Checked prior to downloading 4.23.1. Installing 4.23.1 fixed the departure time issue for me.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Do you still have to enter driver ID? I see no mention of your fix on the thread where you noted you had the same problem as others. There is no way I can send a departure schedule through FP while in this fleet mode.
Jayc
Joaquin
Sweden
Mach e
Hmm
Does anyone else have problem that the icons have disappeared ???
Ford Mustang Mach-E FordPass 4.23.1 just released Screenshot_20230105_110014_FordPass
Jayc
Joaquin
Sweden
Mach e
Note. Based in Sweden
Zassi
Jussi
Finland
Mach-E RWD SR
Does this update actually fix the departure times so that they work without charger connection? I’m using 4.21 and the only time they work is when the car is plugged in…
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
FWIW, this update didn't fix departure times for me at all. Still completely broken.
I can set them in the app, but they never make it to the car. And then when I go to drive the car, and the car checks back in with ford, It deletes the departure times from the app to match what the car has.
ThatGuyLando
Iowa
22 CR1
Software Developer
Sounds about right for Ford software.
Departure times are intended to warm the battery, and then the cabin. To do this requires house current, specifically 240v (120v is inadequate). Therefore, if you want to precondition the battery, plug in.
Departure times will serve to warm the cabin when not plugged in.
GuliblGuy
GuliblGuy
Justin
North Tustin, CA
Eruption Green 2025 GT Mach E
Also to make it work when not plugged in make sure you turn this on
Ford Mustang Mach-E FordPass 4.23.1 just released Screenshot_20230105-064134
