Gullwingdmc
Chip
Boston, MA
It was my understanding that you could read the data available on your car all you want, but that didn’t trigger a refresh. You just saw whatever the last update was. This seems to indicate that when you pole the API it triggers a refresh of the data.
That's not clear to me either. It doesn't refresh every time you check but perhaps it still triggers more refreshes than would otherwise occur and can prevent sleep under specific circumstances.
The refreshing seems to work differently for different people. Several have reported that requesting a refresh from the widget does indeed wake up the car to refresh its data. But that has never worked for me. Nothing I do in the widget or FordPass will wake up the car to refresh its data EXCEPT if I change a charging setting.
Logal727
C
Everything on the widget works fine for me except “View All Data”. I press it and nothing happens, I have latest version. Is this a bug?
I’ve even tried going to Diagnostjcs and copy all data and it doesn’t copy anything.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
That should be working. Are you receiving any errors when you exit out of the dashboard?
Logal727
C
Oh yeah, my vehicle is one that Ford doesn’t have an image for on their server, so I always get an error about no vehicle image. That’s the only error though.
ktn
Current: F150 Lightning SOLD: 2022 Mach-E Premium ER AWD
View All Data and View Module Info have never worked for me.
Only error I can get to show is when I tap on View All Data, no errors with View Module Info, the “Get Data” button does nothing when I tap it.
Code:
All (9) Required Modules Found!
Widget RUN()
(prepWidget) Fetching Vehicle Data | Local: (true)
Script Version: 2022.05.14.0
Update Available: false
Latest Version: 2022.05.14.0
(mainTableRefresh) Refresh Timer Fired
Fetching Vehicle Data from Ford Servers...
(Main Menu) Advanced Info Page was pressed
(Advanced Info) Vehicle Data was pressed
showDataWebView(Vehicle Data Page, Raw Data, vehicleData)
showDataWebView() | Error: TypeError: null is not an object (evaluating 'str.substring')
Last Vehicle Checkin: 28 Seconds ago
FileManager: Saving (Vehicle Data) Data to Local Storage...
Logal727
C
Had an update install today and the OTA page is messed up, I got the install notification though.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 9B6FD177-EE07-4381-91BE-17BDD9BBED46
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Lol... So the widget sent the notification?
I'm working on some bugs right now I will add checks for the errors you are seeing on the view data page.
Logal727
C
Yeah, the update pending message showed up on the dashboard. I think since this update was a special one targeting certain vehicles it didn’t have any release notes so maybe why that error is there.
cbcasas
Christopher
2024 Premium
My OTA info has 2.7.2 loaded as of today (I'm on 2.7.1. currently). How much longer til I can expect an update prompt?
smartino
Indiana
2021 RR Mach E First Edition, 2017 Honda Ridgeline
Turn your car on or drive it and it will install.
smartino
Indiana
2.7.2 requires the car to be turned off to install.
You are right. You turn it in to actually download the update and then once the car is turned off it will install. I got it backwards.
