d-schw33
Daniel
Sweden
Ford Mustang Mach E
Nothing works for me, it started with update prompts every day and then error message "name missing something..." when trying to update.
Deleted everything and even reinstalled scriptable, setting up all again but doesn't get login prompt and widget is empty.
Goober96
Brent
SC
2021 Mach-E4X, 1996 Mustang Cobra, 2008 Corvette
My widget hasn’t updated info in quite a while. The dashboard works fine but the widgets don’t.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
I have exactly the same issue. I've used the widget to open the dashboard and then forced a car refresh and all that works just fine, but the widget hasn't been updated since (judging from the mileage difference between actual and what the widget shows) about 5/29. @tonesto7, any suggestions?
ktn
Current: F150 Lightning SOLD: 2022 Mach-E Premium ER AWD
Yeah something happened in the updates over the past month or so. Just doesn’t work, I’ve had better luck with the small widget but the large one never loads.
Gullwingdmc
Chip
Boston, MA
This is why I am going to create a native ios app where I can control the widgets myself
Can you add in Lock Screen widgets with the new API too ?
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Sure
Just so everyone is clear. This will likely take me a couple of months to get used to developing for iOS and using the swift language.
Gullwingdmc
Chip
Boston, MA
Sure
Nice! If you need any help my husband is an iOS dev and he and I both have Mach-Es. We were just talking to see if there was a way to get access via OAuth, but I think you have to be a partner.
RMoore
Rob
I finally got my MME last Sat and was going to try to learn about scriptable and widgets but given that I’m starting from scratch would it make sense to wait for @tonesto7 to come out with an app for the iPhone? I realize it might take a few months.
Neil4Real
Not much to learn, follow his install guide and you’ll be good in a couple of minutes. Definitely worth doing it for now.
Gullwingdmc
Chip
Boston, MA
Is the widget still working for everyone? It seems like the Apple shortcuts have stopped working because the address they hit is now returning nothing. Same with the update status.
UnforAll
northern Virginia
'21 Mach-E 4x Premium IB; '24 Subaru Crosstrek Sport
Grad Student
Just checked and everything seems accurate/up to date. Widget version 2022.05.25.1 and iOS 15.5
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I changed to the new APIs about a month ago because I saw this coming...
Gullwingdmc
Chip
Boston, MA
Oh nice! Hopefully the shortcuts can get migrated over too. I know that’s not your project though.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I should be able to fix the shortcuts. Can you send me a link?
