JeffGo
- Aug 9, 2021
- Washington, USA
- 2021 Mach-E Premium AWD ext range
I recall a notice I got about a month or two ago from Ford about 3rd party access, something about not sharing your login info. I also had to give up (again) on the homebridge plugin as it kept failing login. I haven't checked the Alexa skill in a while though.I had to remove it. When I first added this the token used by Fordpass also allowed authentication on the digitalservice.ford.com API's used by the Ford Website.
Then a couple of months ago ford started locking down their stuff for the Fordpass and Web separately. So I had to maintain getting two tokens just to provide the OTA data and sync info.
Now they've locked the token process down pretty well by adding a unique fma_verifier cookie to the login process to get a particular token version required to access the OTA info and it's just too hard to capture using Scriptable at the moment.
I'm all good with the added security but they need to allow authorized access to the API they created which is technically the same one we use for Ford Pass.
Ford Developer Marketplace | FordConnect
It has all of the calls available except the one to get your token
