JeffGo
Washington, USA
2021 Mach-E Premium AWD ext range
I had to remove it. When I first added this the token used by Fordpass also allowed authentication on the digitalservice.ford.com API's used by the Ford Website.
Then a couple of months ago ford started locking down their stuff for the Fordpass and Web separately. So I had to maintain getting two tokens just to provide the OTA data and sync info.
Now they've locked the token process down pretty well by adding a unique fma_verifier cookie to the login process to get a particular token version required to access the OTA info and it's just too hard to capture using Scriptable at the moment.
I'm all good with the added security but they need to allow authorized access to the API they created which is technically the same one we use for Ford Pass.
Ford Developer Marketplace | FordConnect
It has all of the calls available except the one to get your token
I recall a notice I got about a month or two ago from Ford about 3rd party access, something about not sharing your login info. I also had to give up (again) on the homebridge plugin as it kept failing login. I haven't checked the Alexa skill in a while though.
Bayviews88
Kenya
SF Bay Area, California
2022 CA Rte1 RWD, Space White
I reset my login information in the app. After setting up the widget again on my iPhone and logging into FordPass I’m getting the following error.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 43F264DC-D8E6-46D3-8349-90EDDD231AD8
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 81492CA5-E11D-4C02-8E46-AD26DED46E51
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Use the widget tool to force a full code refresh and try again
connoisseurr
Connor
Northern VA
22 Rivian R1T, 23 Tesla MYP
IT Engineering
Getting the same error, after a full uninstall and reinstall.
CommittotheIndian
Travis
Indiana
2022 Ford Mach-E Select eAWD Star White
Indiana Supreme Court - IT
I don't think this is a code issue, maybe a scriptable issue with iOS 16.
I had been using the medium detailed widget but switched to the small detailed. I've noticed it does not want to update even though scriptable itself is updated.
Has anyone else run into this issue and if so did you have a fix?
ORG
Randy
2021 Mach-E Premium, 2021 Bronco Sport Outer Banks
same issues as above, anyone get this to work yet?
bmwhitetx
Bruce
2022 F-150 Lightning Lariat ER
I tried it for the first time today (with my Lightning). First it could not find any VIN's on my account. Once I pasted that in though I get a choice of styles but when I click Save I get the same error as @Bayviews88
AlexPT
Alex
Portugal
MME RWD Extended (Ordered)
Since I’ve updated the widget I now have the same issue, as above. Not able to use the widget any longer.
Additionally, I see on the login popup window that there’s region = NA, not sure it’s something new or related to the issue, but I’m in Europe so decided to post.
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) A6294238-4B7B-4837-92EE-0C2C9E976DAD
Djynn81
Jeremy
Mach-E premium
Medical
Ford Mustang Mach-E FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 708600FC-D64B-4E3D-A748-3F9C9A62F945
Anyone know what this means working fine yesterday
notaek
2022 Mach-E Premium ER AWD
Same here for the past few days, but I’m on iOS 16.1 so I was thinking it’s that / Scriptable.
737flyer
Richard
Redington Beach, Fl
2014 BMW X 5, 2021 Mach E-Premium RWD Job 2
Retired Airline Pilot
Mines out too. I guess the author has to fix it.
CommittotheIndian
Travis
Indiana
I believe NA refers to North America (although for the longest time I thought, Not Applicable). Are you able to change it?
