FORScan MME spreadsheet
MVasco
Manuel
Spain
Mach-e 2023
Thanks it worked and looks well both Regen and power are working!
Glad to hear! Hope somebody can help with UFO and backup sound. I haven't been able to switch it off.
Chapron
Detlef
germany
Mach e RWD EX TP2 / 2023.75
SAP Engineer
What I next like to remove is the powerlift rear door beeping When opened or closed by motor.
Chapron
Detlef
germany
SAP Engineer
Hello. What doest Bideo on demand do ?
Ford Mustang Mach-E FORScan MME spreadsheet IMG_5128
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
The only post I could find says “It allows you to watch DVDs on the Nav screen while the car is in Park. Not so with the GT350. I enabled the parameter, but the DVD I inserted wouldn't play“. Not sure he is correct. If he is, not sure it’s useful or supported on the MME.
Chapron
Detlef
germany
SAP Engineer
I try to enable the speedlimit exeed chime in ipma(I guess). The option switch is enabled in APIM and there but the function it self is not there. Any idea which that is in the spreadsheet?
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
there are many posts about removing the backup sound. It involves physically disconnecting a speaker in the back of the car, and making a change in forscan so that the speaker disconnect doesn't produce an alarm.
HughJazzol
Norman
Miami
which speaker do you plug it into? Tried looking for instruction online but didn’t find any. Does the product come with them?
there is a post or 2 explaining the 2 steps required to remove the backup beep. You have to disconnect a speaker in the back of the car, and then make a change in forscan so that the disconnect of the speaker doesn't generate an alarm. Look for it under the Interior Mods forum, probably.
MVasco
Manuel
Spain
Mach-e 2023
I would be more into disabling UFO sound than backup sound. Is it the same speaker?
Chapron
Detlef
germany
SAP Engineer
Would be the Police dark mode an option? Havnt tried it (yet) :cool:
I tried to do the same thing on my '21 several years ago and could not get it to work. Remember, these options/settings are not just for the Mach-E. Most do nothing for this car.
Chapron
Detlef
germany
SAP Engineer
I agree but the car did that in the beginning and after whatever OTA this went missting.
Yes, OTA updated do tend to mess with some settings we make in FORScan.
There are many posts about removing the backup sound. It involves physically disconnecting a speaker in the back of the car, and making a change in forscan so that the speaker disconnect doesn't produce an alarm.
Not sure about the rest of the world but in the US, there is only one speaker and it is in the front of the car, not back. Both the Pedestrian Warning sound and back-up beeping come from that speaker. The easiest way to disable this is to remove the connector going to the speaker and shove a 4 ohm resistor into that connector. That is it. No need to mess with FORScan.
Jetsurly
Tom
Minneapolis
2023 MachE GT
Med Sales
Is there a change to disable or increase the “eyes away” when using both BC and cruise control?
