santa fe,nm
www.envirokarma.org
Solar Sales/install
A similar issue started out intermittent with my 2021 and it has been constant for thousands of miles. I get pre-collission assist not available and front camera fault service required. Cruise control doesn't work either.
They told me the module is failing and there might be an issue with the wiring. I can't tell if they're bullshitting me on the module or not. I haven't tried to take anything apart.
it's the connectors themselves. very delicate, and if you had your windsheild replaced, or the glue re-done with the recall, that probably started the problem.
just jam some foam between camera and connector to keep it from vibrating.... works 99.9 percent of the time for me. only blinks if I hit a rough bridge seam at 80mph
ERIC8585
Eric
CA
2021 Mach-E RWD
Cool, I'll try taking the cover off to look. Never had the windshield replaced nor the recall.
santa fe,nm
www.envirokarma.org
Solar Sales/install
someone22
Europe
2022 PE AWD
This might already go offtopic a bit, but more into the technical stuff. I've managed to source the connectors and cable, made myself a fitting cable but with hand-twisted connections. This did not work as GMSL2 (which I assume is the protocol) with PoC works at over 2GHz, not something you can twist or crimp in your home shop.
Studying GMSL2 and PoC circuitry, it seems that at least there should be some voltage to be seen with a basic scope. I also live in an area where automotive is the bread-and-butter, and managed to get one senior engineer to explain what should happen He argues that there should be a constant DC offset even with a non-functioning camera. I did not see this in my tests; I've already ordered a new factory cable which should arrive in 3-4 weeks.
As an explanation, to the best of my knowledge: the IPMA and front camera communicate over a single coax. Since power is also applied, it's called PoC. The protocol is likely GMSL2 (but it could be 1 or 2). The IPMA provides power to the camera while also measuring the cable impedance/shorts/opens. Once the IPMA can read the serial of the camera (the camera is paired), communication continues. Since there is a single coax cable, the IPMA applies some power (voltage) to the cable and waits for the camera response, I assume either 5V or 12V. The data "rides" over the DC offset. There are some power management ICs that deal with PoC and can sense the trasmission line and decide whether to go ahead or not. I have only seen datasheets from TI, but haven't opened the IPMA to see which chips they actually use.
To add another layer, even if high-speed Fakra is used, it seems there are different plugs jacks and crimping standards. I have an "identical" 4-coax connector but the center pin is slightly recessed, which means connection is unreliable. Speaking to GMSL / camera devs, the RF integrity is very important, so only the Ford-specced cable should be used. The physical differences are invisible to the naked eye, like 0.1mm shorter or longer or wider.
Not good news, but I wanted to somewhat summarize my two weeks of intel gathering. I spoke to a few people developing the ADAS systems, the suppliers, to people in the fabs making the cables. It's unfortunate that a cable that's made within a 0.2-3h drive has to travel 3-4 weeks to get back home.
This should be another topic, I think, but it solidifies a bit the knowledge for the ADAS camera.
sukhoi_584th
United States
2022 MME CR1 AWD
They couldn't just use HDMI with PoE? 🤣
someone22
Europe
2022 PE AWD
Maybe HDMI is unsuitable for automotive environments, no idea. I have not try messing around more with it, but I couldn't see the DC offset at all. Wondering if resetting the IPMA through ForScan is the way to reset the errors or if the Ford software has to be used instead.
someone22
Europe
2022 PE AWD
Bad news, I've replaced the A-pillar to IPMA cable but still no dice. Also checked the fuse under the hood (it's almost a 1h job). At this point I'm suspecting the IPMA, but not sure where to go from here.
ChehRob
Rob
Seattle WA
ret
I had my MME at the dealership, and in a first sign of competence they diagnosed it, did a temporary repair, and said Ford was working on the permanent fix. I can post the software issues on that if anyone is interested.
someone22
Europe
2022 PE AWD
For sure, I think many people are watching this thread, probably a lot of them are not even registered users. There has to be a reason for all these failures, another one besides the sloppy windshield change and/or bad routing. The fact that there is a TSB and it has a "parts shotgun" approach certainly points to this.
Gary
Scottsdale, AZ
Mach-E Premium Rapid Red - Std Battery, RWD
Attorney
Yes my car is at he dealer b/c we got the same errors for quite a while now where several camera related issues pop up. so the replaced camera and wiring and still cant get it to calibrate - or as they say programming issues - and now say they are requiring engineering assistance. And yes i've had the windshield replaced - twice - b/c of rocks that did big-time damage. wonder if that started the issue - cant remember as it was a couple years ago. dealer had said they replaced camera and wiring b/c if they had only replaced one in the past, then the problem didn't seem to be fixed. so i wonder about the module / IPMA.
santa fe,nm
www.envirokarma.org
Solar Sales/install
mini-coax connections, even the ones with "lock-slides" are not great for situations with vibration, or more than a few disconnects/reconnects... and the wire is tiny, which is sensitive to bending, strain, or pulling.
My opinion is that the connector is the point of failure, and could probably be best addressed with a different type of connector and heavier gauge wire to avoid damage when windshields are replaced, and/or subject to vibration from washboard dirt roads or significant hits from road-seams that suspension can't eliminate
someone22
Europe
2022 PE AWD
These mini-Fakra connectors have been developed for the automotive environment and most of car manufacturers are using them. GMSL and PoC were also developed for this purpose. Unfortunately it seems that either the chosen cable strength or routing is a major pain point as well as lack of diagnosis tools from the OEM. They should have provided Ford with the necessary tools to put the IPMA into service mode. I am sure this lack of foresight is costing them a lot in recalls and extended warranty repairs.
I'm still hoping someone can unclutch the OEM software from somewhere or at least the necessary CAN commands to perform service tasks.
