Does it come with the cable to connect to the LVB? if not, what guage cable is recommended?
No cable, this is just the access point. The gauge of cable you want to use is dependent on how much peak amperage you will be pushing through. An ICE with a big, high-compression engine is going to need a lot bigger cable than an EV. Since we’re running approximately 40A @12V- while running FDRS, I chose 10AWG copper and a 50A fuse, with all terminations and splices double-crimped. The lugs on the back of the access point are large enough to accept any size battery cable. ??
krazieboy
US
Mustang
Thanks! Thinking of doing this as a future mod. I love the clean look.
JoeBeach
Central Florida
Mach E Premium 2WD ER, F150
How did you attach to the positive cable in the Mach-E? It has a strange bevel shape.
Positive cable is attached directly to the middle stud on the positive battery terminal. ??
Ford Mustang Mach-E Frunk Tub Removed [Pics] 71A8EF7B-015A-4210-95FE-872A3D4A1547
The negative cable is attached to one of the chassis ground points on the left strut tower, way down low. Kind of hard to get to. ??
During another frunk removal to replace the jump point that I broke, I noticed after a couple of FDRS sessions the quick-disconnect was getting fried. So I got a forklift charging terminal to use as a QD under the jump point. Both have the same 50A rating, but obviously the QD doesn’t meet spec. The forklift terminal looks obviously able to handle müy calienté juice, so I am optimistic that it will hold up better. Forklift terminal on top, old QD below in the photo
Ford Mustang Mach-E Frunk Tub Removed [Pics] 46AFE205-2E7A-4D85-9D08-2A4679BB5443
And I added some reflective orange tape to the underside of the lid to prevent screwing it up again: ??
Ford Mustang Mach-E Frunk Tub Removed [Pics] 53D1FDD3-DA3F-4B3A-9737-7F873709FA49
Mike G
N. AL, USA
Wiring rough-ins done. ??
Used heat shrink tubing at intervals to keep the red and black wires together. ??
Quick disconnect roughed-in under the mounting hole for the access point so that the access point can be removed or the beauty panel can be removed with the access point still screwed into the beauty panel. ??
And a quick mock-up of the access point with wiring installed. Access point is not fastened to car yet. Have to wait on the ABS reinforcements to dry on the threaded inserts (and dumb-dumb doggie here forgot what he did with the mounting screws). ??
Is that 10 gauge wire on that SAE connector?
Mike G
N. AL, USA
Mrtman
Kowalski Dwayne
Chestermere, Alberta, Canada
2022 MME GTEP
Retired IT then Long Hall trucker for a bit
I'm doing this EZCB mod also.
Did connect the cables directly to +/- on battery?
Thank you
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Thank you
Yes, for the positive, but not for the minus. You need tp pick that up from a ground on the vehicle, not directly from the battery. (If you connect to the - terminal on the battery, you'll be connecting before the BMS which will screw up the management of your battery.)
Thank you
I used the +12V battery post and a grounding point in the left strut tower. Do not attach anything to the -12 V post since that will bypass the BMS sensor. ??
Mrtman
Kowalski Dwayne
2022 MME GTEP
I also noticed you replaced the original QD with a forklift connector?
Yep, the supposedly 50A capable QD melted during a FDRS session. The forklift connector has better cooling and spaces the conductors further apart. It’s meant for the amperage and duration in the same way that an industrial outlet will work better for our EVSEs than a consumer-grade outlet. ??
Did you stick the 10awg wiring?
Yes, I stayed with 10AWG since the highest draw I have seen doing FDRS updates is 43A. ??
