Home Level 2 Charger Issues
louibluey
FE "Louibluey" GB
This is exactly what he was talking about. I'm at 257V, so his thought is that it will drop it below 250V. I suppose I should read into this some more.
That also won't help if the problem is power line distortion (no filtering), and especially not if it turns out that over voltage is not the problem.
malba2366
911 C2S
I am completely at a loss. ComEd has already come out and said they’re within the limits. Ford has a very conservative threshold for voltage. Neither seems to be willing to do anything to address my issue. My electrician has found a step-down solution that’s going to cost me at least $500. I’m irritated that I have to do this because other manufacturers’ EVs are tolerant of ComEd’s supply voltage.
Has an Engineer from Ford told you what the charging threshold is, and that they won't change it - or is this something the dealer said?
jparduhn70
jparduhn70
Knoxville, TN
2021 Mach-E First Edition
I'm in Florida and am at 248V and have never been able to charge. I would see what the Ford engineering team comes up with because this isn't geographic/provider specific and given the range of voltages on the tracking spreadsheet I'm not convinced that's the issue either.
I'm not convinced that this is a location services issue either. If you saw my earlier post, I can't charge the vehicle in Illinois at 257V, but in my house in Tennessee, it's working at 248V. I disabled location services in FordPass a few days ago, but still couldn't charge in Illinois. After successful charging in Tennessee, I re-enabled location services and it still works. I'm hoping I get lucky like @Brademcee and am able to charge when I return to Illinois tomorrow, but I'm doubtful.
jparduhn70
jparduhn70
Knoxville, TN
The dealer stated that there was an overvoltage error in the OBD logs. Ford engineers have not looked at my vehicle specifically.
jparduhn70
jparduhn70
Knoxville, TN
I haven't committed to putting in the buck/boost device yet, so it's just an option at this point. I don't know what to do, anyway. If Ford was more receptive to my concerns, at least providing me with some dialog, I probably would just let it sort out. The utility isn't going to do anything, so I'm counting on them, but so far am very disappointed with the progress, or lack of it.
Sweetwater
Jeep
Retired Electrician
Sure you could Buck it down to 240 volts but if your incoming 257 volts
changes so does 240 volts
The secondary voltage (240) is in direct proportionally to the incoming
voltage. If he Bucks 9 volts off the 257 it will always Buck 9 volts off the
incoming voltage. If you on a few days have 240 v incoming then the
transformer will still Buck off 9 volts giving you 231 volts.
prdude
pleasant ridge, MI
engineer
Not to hijack this thread, but this is convenient to post here, since so many folks who understand electrical stuff are following this thread (I always struggled visualizing the moving around of electrons).
Anyway, I'm seeing issues with the Ford mobile charger, when hooked up to the 115V outlets in my detached garage. Basically, I get an amber light from garage outlets, but a blue light from an outlet in my back porch (different circuit). When checked with my multimeter both the garage and porch outlets read ~126V.
What else should I check on the garage outlets? Note that I was able to use the mobile charger for my Fusion Energi on a garage outlet.
Sweetwater
Jeep
Retired Electrician
Check the polarity of the recp. Hot and neutral correctly wired and also
the ground is there. The recp short slot is Hot The long slot is neutral.
I posted this earlier in this thread, but it's worth repeating:
ANSI C84.1 is the standard utilities in North America are supposed to adhere to for voltage tolerances. There are two ranges: Range 'A' and Range 'B".
Range A is what the voltage should be during normal operation. That range is 228-252V.
Range B is looser and is only supposed to occur infrequently due to abnormal operating parameters. That range is 220-254V. If Com-Ed is saying 257 is normal, either they don't follow ANSI C84.1 or the person who told you that doesn't know what they're talking about.
Here's a link to the standard, if you want all the gory details.
DaveQ
Fernandina Beach, FL
Mach-E4X, HR-V, Insight, Maserati Levante S
Is this going to be a problem? I take delivery this week!
Ford Mustang Mach-E Home Level 2 Charger Issues Screenshot_20210322-215725~2
malba2366
911 C2S
Yeah but the car will charge fine at 231 (just a bit slower) - it has to accept lower voltages because it has to work with 208 as well.
prius2pony
Jeff
Mach-e Premium First Edition
When it was working, was it overnight? The more power a solar inverter is inverting, the more EMI noise it can put out. For example, my wife's garage door opener remote (closest in the garage to the inverter) rarely works at high noon but works fine at night.
The successful charge was mid day, when panels were producing well.
bruceski88
Bruce
CA
Mach e
Retired Engineer
Range B is looser and is only supposed to occur infrequently due to abnormal operating parameters. That range is 220-254V. If Com-Ed is saying 257 is normal, either they don't follow ANSI C84.1 or the person who told you that doesn't know what they're talking about.Here's a link to the standard, if you want all the gory details.
Another EE here with his 2 cents. Most of you do not have a voltmeter that really measures AC voltage. Your meter rectifies the ac signal and measures the peak voltage. Then it assumes a perfect sine wave and multiples the reading by .707 to give you an approximation of the AC RMS voltage which should be 240V. If you have nasty harmonics or a DC component it won’t tell you that. An Oscilloscope and a true RMS voltmeter is the best way to see what’s going on. A $200 meter will make the true RMS meaurement. https://www.amazon.com/Fluke-117-El...t=&hvlocphy=9031936&hvtargid=pla-434797909169
It is possible that there is a damaged transformer messing up your power, but the whole state of Illinois? I speculate a software problem.
Good points.
I was presuming the voltage measurement was verified by ComEd, which one would hope would be accurate. And I also agree about how widespread this is or is not. I could see maybe one substation being set too high, but not all of NE Illinois or all of ComEd. Some utilities will hook up a power quality monitor for a couple of days at a service when requested by a licensed electrician who suspects power problems.
A true RMS meter is definitely the way to go. An untrained individual should not try to hook a scope up to measure powerline voltage. A saw a technician try to hook up a Tektronix scope to measure 208V from a generator. The probe lead melted in his hand when he tried to attach the grounded lead to one of the 208V busbars!
