How cold is the frunk?
Tangible
2021 Job 2
I’m going to be traveling for several hours with some frozen food, with outside temperatures in the 20s F. Will the frunk temperature be the same as the ambient temperature, or does it pick up heat from components under the hood or from the heated cabin?
I don’t know the exact answer, but based on experiences reported here by people icing down their beer in the frunk during the summer, I think you’ll be fine.
MachMachWhoThere
Pennsylvania
2021 Mustang Mach E GT Iconic Silver
I hid some Christmas presents in mine when I left a store the other night. It was about 40F out. The back plastic wall of the frunk was warm to the touch.
You should not think it will be 20 degrees, no. Use a cooler.
hybrid2bev
2026 Rally
Last winter we drove 150 miles with a big snowball in the frunk. It was 15F outside. When we got home, no snowball.
GoGoGadgetMachE
HEY, THAT'S A PERSONAL
oh the car's frunk
you're good
(also it seems to be vaguely the outside temperature as there's no formal insulation but the metal and plastic do a small bit of insulating and as @MachMachWhoThere suggested there's some heat from the climate control [*] that "leaks through" to the frunk from behind it.)
(*) it occurred to me a few years ago that the very common industry term of "climate control" is kind of dumb. you're not controlling the climate or anything like that. it's not even "weather control". it's "car comfort control" or something. (even that name is stupid.)
Tangible
2021 Job 2
Thanks for the responses. I have a thermometer that normally lives in my home freezer and communicates wirelessly to a base unit. Maybe I’ll put it in the frunk for a while today to get a definitive answer, which I will post here. It would be good to know, both for keeping things frozen and conversely to avoid freezing things that shouldn’t be frozen.
Merriam-Webster covers this in definition 2b for climate:
“the prevailing set of conditions (as of temperature and humidity) indoors,
e.g. a climate-controlled office”
Other meanings are possible, such as, “If you want to check out the view from the top of a mountain, climate.“
GoGoGadgetMachE
huh. who am I to argue with the dictionary? ?‍♀
On my car, the temp displayed on the upper right hand corner of the sync screen is the front compartment temp. Probably because the sensor is located in that same general area. I have always assumed the reading was ambient temp but that isn't always the case. Every time I have measured the temp in the front compartment, it has been within a degree or two of the reading on the screen.
Yes, it picks up heat from the under hood components.
Tangible
2021 Job 2
Experiment concluded.
Conditions:
Outdoor temperature oscillating between 36 and 37
Cabin temperature set to 70
Overcast and raining, so no solar heat gain
Results:
After an hour, the frunk temperature stabilized at 46. This indicates significant heat coming from under-hood components or leaking from the passenger compartment.
Conclusion:
The frunk is a better location for frozen items than the trunk, which is open to the heated passenger compartment, but it would be prudent to use an insulated cooler containing ice unless outdoor temperatures are at least ten degrees below freezing. Conversely, items which should not freeze, such as fresh produce or dairy, can be safely transported in the frunk for some time unless outdoor temperatures are very low.
breeves002
St. Louis, MO
2021 Mach-E GT PE
The frunk gets the heat from the radiator and condenser blown directly onto it. This heat is from 2 sources..AC compressor which may run even at low temps to defrost, and the motors/inverters. So you'll get heat no matter what. The frunk is awesome for putting take out food in in the summer. Keeps it nice and toasty and cabin doesn't smell.
breeves002
St. Louis, MO
2021 Mach-E GT PE
But those aromas are great foreplay for the meal. It's important to get in the mood.
That is a fair point, but I don't want the car to smell like crap the next time I drive it. It's great on the drive home, not so great the next morning :p
Plus hot food is better than the smell.
Conditions:
Results:
Conclusion:
I suspect your conclusion about "unless outdoor temperatures are at least ten degrees below freezing" may not be valid.
KevinS
It clearly won't be cold enough without ice in there. Otherwise Ford would have just filled it with shrimp for the tailgate party photo.
