GoGoGadgetMachE
Yeah, flatter and no chew marks from the prior removal. It’s the little things in life.
ah, I did better removing mine I guess ;)
flatter is interesting though.
Solarguy
Barry
San Jose
E55, Volt
Swiss Army knife can opener attachment. I removed all the clips in a few minutes by prying the curved edge under the clip, levering up the clip a bit, then pulling it all of the way out. Only slight deformation on the clip, and I didn't have to buy a special tool.
Macheeee
Stu
2016 F-150, 2013 Honda Crosstour, 2010 Audi A5 Con
Self employed
center divider hack
Love it! Did you turn it upside down after removing or trim the bottom tabs?
louibluey
FE "Louibluey" GB
Some creative solutions here to pull the fasteners.
But, for tool geeks, one of the best parts of any project is the excuse to read about and buy a new tool :)
mikeho
San Jose, CA
Just curious, for those that have taken it out, what happens if water leaks through the holes? I took mine out but I'm worried that it I put ice or hose it down, the water will leak into sensitive components.
2thmanfl
Steven
St Petersburg, FL
2021 Mach-E (wife), 2023 Tesla model 3 (me)
Dentist
wait I'm looking at this and I still don't get it, how is this better than the original ones? flatter?
And on Amazon suggested under that was these, which I will probably get. (haven't measured yet to be sure they are correct dimension).
https://www.amazon.com/GOOACC-Faste...75D71CTKAQA&psc=1&refRID=GBKXS2X1P75D71CTKAQA
Removal was about 15 minutes with screwdriver and pliers, and I reinserted them after remolding the few screw pieces that bent slightly.
I was familiar with these fasteners as they are the same used for the hatch divider covering the battery compartment on our jetskies, which I had to remove 1 week ago.
The plastic pins and holes holding the frunk dividers in place were never watertight. If you remove the dividers and reinstall the pushpins, the enclosure will still not be watertight. I wouldn't worry about it too much, it's hopefully been considered in its engineering.
That's exactly why I've purchased the official after-market Mustang Mach-e Frunk Koi Pond liner.
louibluey
FE "Louibluey" GB
There are openings to the road below, I wouldn't worry too much about those small holes. I put the fasteners back in mine, just because it looks better.
I don't think you have to worry about it. I've had the storage bin out and gave it a good look. Nothing different than any other engine compartment that I have seen with watertight connections on all the plugs. If water were to get through the holes of the divider, it certainly would'nt be much and only probably a slow leak or drip. It will run straight down the side of the bin and drip underneath it. As Jonathan said above, I am sure engineering considered this.
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup IMG_42761900
louibluey
FE "Louibluey" GB
Here are some pics of the open road down under (both sides, the openings are about a hundred (thousand?) times larger than the area of the fastener holes).
I have it open while doing Mark's subwoofer project, back to work!
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup IMG-1578
Ford Mustang Mach-E How to - Remove Mach-E frunk divider - DIY writeup IMG-1577
