RyanSD
RyanSD
Ryan
2021 Ford MME AWD EXT, 2013 Yamaha Stryker
IT Systems Architect
PeeKay
Pravin
Sunnyvale, CA
2021 Job 1 MachE
A few questions:
1. So you have to control the gas/brake while OP controls the steering?
2. Can one co-steer like BC, or does OP give up like Tesla?
3. How does one switch back to BC for a trip?
4. Is longitudinal control looking like it's going to happen in a couple of months?
5. Is there a 2nd hand mkt with Comma 3x, if one doesn't like it?
AjzRide
Alan
Houston
RR 2021 MME Premium RWD
Eng
A few questions:
Not at all. Ford Adaptive Cruise Control is active and controlling the gas + brake, and OP replaces the Ford lane centering logic. Using OP is very similar to using BC except better. The biggest difference is that OP engages as soon as you engage cruise control, rather waiting for you to turn on lane centering.
2. How does one switch back to BC for a trip?
There is a simple toggle in setting to turn the Comma into a Dashcam and disable all logic, reverting back to BlueCruise (You'll never want to do do this one you try OP)
3. Is longitudinal control looking like it's going to happen in a couple of months?
I don't think so, but it looks like you misunderstood how it works, see item 1. I don't think long control is a big deal. It's mainly only needed for full self-driving features like stopping at red lights and making turns fully autonomous.
4. Is there a 2nd hand mkt with Comma 3x, if one doesn't like it?
It shouldn't be hard to sell it used, but they also have a 30 day money back satisfaction guarantee.
briankwest
McAlester, OK
2023 F-150 Lighting, 2023 Mustang Mach-e GTPE
After running OpenPilot for a few weeks, I've moved over to a popular fork called SunnyPilot and was able to resolve the fingerprint issue by modifying some of the Panda code in uds.py and adding the Mach-E ECU values. Vehicle now being recognized properly.
I maintain my own personal GitHub fork for personal usage and highly recommend, to anyone interested, do the same.
Did you do a pull request to update SunnyPilot for the ECU values for the Mach-e?
RyanSD
RyanSD
Ryan
No, I have my own fork and update/add the values needed in my personal branch. All pull requests, regarding fingerprinting, should be against the commaai/openpilot/master and then they will be pulled into SunnyPilot. Several of us have PRs with commaai/openpilot to help with Ford fingerprinting.
@AjzRide Since there is no longitudinal control, does that mean you can’t use OP in traffic? Because it won’t slow down for cars in front of you?
AjzRide
Alan
Houston
Eng
Ford ACC slows down for traffic, that is by definition what ACC does.
So is Ford’s software stack running the adaptive cruise portion and the open pilot stack is just doing the steering? Or is open pilot also intercepting and using the radar data?
Also curious how this will interact with automatic lane changes.
Hammered
SE US
2022 PB F150, MME GTPE
For now it's using ford's ACC unless you want to try and use one of the experimental features. Eventually it will start to use the vehicle's own sensors but right now it's relying on stereoscopic vision. It's continually evolving and shouldn't be seen as a static fixed feature set.
What makes its driving capabilities better is that it's using machine learning to understand how the vehicle drives/handles, unlike bluecruise where you've got to input all of the vehicle's specs so it can run handmade algos. The OP software stack learns all of that on the fly.
It's smart enough to know if you have an alignment issue or under-inflated tire. That's the level of sophistication the device brings in its current software, with plenty more to come. They have hours of videos on their YT channel that are worth the watch.
briankwest
McAlester, OK
Should be there on the cars with radar, like the Mach-e and Lightning from what I can tell.
PeeKay
Pravin
Sunnyvale, CA
2021 Job 1 MachE
@AjzRide , are Comma employees writing the Ford specific layer, or is it community members?
Could you also please share the GitHub fork of the source code you use on the F150?
Thanks
AjzRide
Alan
Houston
Eng
Thanks
The community is developing ford at the moment. I installed stock OP and then used SSH to hardcore my fingerprint and disable dash cam:
connect to Comma3x via SSH:
sudo nano openpilot/launch_openpilot.sh
#!/usr/bin/bash"
export PASSIVE="0"
export FINGERPRINT="FORD F-150 14TH GEN" <==== Add this line
exec ./launch_chffrplus.sh
sudo nano openpilot/selfdrive/car/ford/interface.py
class CarInterface(CarInterfaceBase):
@staticmethod
def _get_params(ret, candidate, fingerprint, car_fw, experimental_long, docs):
ret.carName = "ford"
# ret.dashcamOnly = candidate in {CAR.F_150_MK14} <==== Add the # at the front of this line
ret.radarUnavailable = True
ret.steerControlType = car.CarParams.SteerControlType.angle
Reboot the Comma3x
