PeeKay
- Pravin
- Apr 2, 2021
- Sunnyvale, CA
- 2021 Job 1 MachE
- Retired
It’s the exact same process if you install SunnyPilot. I dabble with both.Cool. Thanks @AjzRide
For some reason I thought you were running SunnyPilot. Perhaps I'm confused...read too many threads on too many forums.
1) Yes. I am running an experimental fork now that is using radar. Still a work in progress, but proves it is possible.For those like me with only a superficial understanding of the technical details ...
1) Is it possible (perhaps on a future Comma SW version) to incorporate MachE's inbuilt radar sensor data for Comma-controlled ADAS? Potentially to deliver enhanced ADAS or for redundancy.
2) Can Ford disable CommaAI thru one of their OTA updates, assuming they can figure out who is using Comma from the vehicle data they collect?
3) Could Ford void the new car warranty for Comma users because they are messing with the electronics in a non-authorized manner?
Thank you so much! The "getting started" PDF you provided is amazing. I am running SunnyPilot now in my Honda and I always struggle with which settings to enable/disable. Thanks to you, I won't have that problem when I move it to the Mach E. I really appreciate the work you are putting into this.Yes, SunnyPilot is the best way to go, it supports MachE out of the box, no need to make a custom fork or ssh in to get out of dash cam mode. There is a team of about six working continuously on Ford, and we have submitted several code updates to Comma and Sunny to improve the experience for everyone. I am hopeful Sunny will get them incorporated in the next few weeks. Comma will be months before they incorporate. There are two big changes we have suggested. The first is to acceleration/braking control that adds in the ability to coast so braking isn't binary. The second resets steering whenever a human made turn is initiated to prevent the wind-up that you experience if you make a turn with lateral controls engaged.
Yes please! I would love some help. How do you have the cables routed? How did you access the IPMA? What did you use to know how to access the IPMA? Service manual? Do you find SunnyPilot is better than BlueCruise? Did you run into any road blocks during installation?If anyone still needs help with this I have comma in my car. I was lazy with cable routing and I have a 3 not 3X so I have power and data running to the device. Getting to the IMPA in the trunk is a pain.
I'm not super into the software but SunnyPilot has the ACC. Run the OP long option not stock. I can try and answer questions but your best bet is probably the discord.
I wrote a fix for this and Sunny is safety testing it now. Should go public in the next few weeks.With low speed manuvres it is weird as it tends to "hold" a turn after its complete due to ford using a curvature measure instead of torque.
