NEMA 14-50 wiring question
Chuck
Chuck
SoCal
Mustang Mach E 2021
I watched the video where "industrial grade NEMA 14-50" plugs were catching fire because of lesser quality than the Hubbell connector. So I opted to replace mine with a Hubbell after 16 months of ownership. My original plug was installed by an electrician and has worked fine for 16 months.
To my surprise, when I went to pull out the original plug, it had only 3 wires. There was a ground and two black wires. Nothing was connected to the neutral connector where the white wire should go.
My question is: Do I need an electrician to come out again and install the neutral? Or can I just go along with the way it has worked since the beginning?
Garbone
Gary
Loafer
No
There are no EVSEs that use the Neutral wire, so it’s not necessary. It's really only necessary if you want to pull 115/120V out of the outlet. That’s highly unlikely since you will probably only use the circuit for the EVSE. Since EVSEs don’t use the neutral, I have wondered why so many manufacturers settled on the 14-50p on their units rather than the 6-50p. Toe-MAY-toe, toe-MAH-toe… ??
The neutral line is only needed if the EVSE requires 120V as well as 240V, which I assume isn't typically necessary. I would say the EVSE you have (and probably the vast majority) don't need it.
Probably because the 14-50 is much more prevalent
But it wasn’t when I bought my EVSE. Back then, it was a pretty fair split between the two standards. Maybe they felt the ”oven” plug/receptacle were better suited than the “welder” plug/receptacle at some point. My 6-50r consumer-grade outlet has been just fine for nearly a decade though. ?‍♂?
The EVSE doesn't need the neutral wire, but technically a 14-50 receptacle has to have a neutral connected by code. I wouldn't worry about the neutral if you know the outlet will only ever be used for an EVSE.
bshaw
Boston, MA
I believe an RV is a common example of something that will expect to find a neutral wire in a 14-50 outlet.
I think there will be a shift back towards 6-50 once 240V EV outlets are required in new houses by code. 6-50 saves some copper, and electricians are cheap bastards when it comes to new home wiring so they will do it to save a couple bucks.
chrisGT
Northern California
2021 Ford Mach-e GT
I guess the installation wasn't inspected by city otherwise they should have caught the missing neutral.
I suggest that you try have the original electrician come back run a neutral because their work does not meet the electrical code and they practically "cheated" you by saving wire cost.
I had my electrician wire my hardwired JuiceBox, and insisted they use 4 conductor wire. I have an unconnected neutral in my box, so I can connect a standard 4 conductor 14-50 in the future.
LOL *I* am a cheap bastard. Perhaps because of my Asian Redneck Poodle upbringing. ??
But I believe it was certainly much more common in campgrounds (@JamieGeek can confirm that) and in general in homes for appliances - I can't say I've ever seen a 6-50 in person in any home/apartment I've been in, although that isn't a very large sample size. For point of reference I've redone the kitchen in both houses I've owned and worked for a time for my brother's general contracting business.
It’s not a code violation to not have the neutral on a 14-50 unless there is another 14-50 on the premesis with a neutral. (Section 406.8 requires all configurations of an outlet to have interchangeability).
But it’s probably not a good idea.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
14-50's are in campgrounds because the RV's that use them have two A/C's: Each wired to one leg of the 120V provided--they don't actually use 240V between the two hots.
When the electrician wired our house for an EVSE back in 2013 he did a 6-50.
