YesYou're saying I can't precondition the battery if I'm using Level 1 charging? I'm just warming the cabin up?
That is correct and I believe you are also draining the HVB as the L1 supply does not cover the entire heater load.You're saying I can't precondition the battery if I'm using Level 1 charging? I'm just warming the cabin up?
How can you tell if the car has been preconditioned? Say i set up a departure time for an hour from now, how can I tell?
You can hear it. Depending on the temp it will start by conditioning the batteries you can hear the recirc pump working and see the charger is drawing power. The app will also tell you it is doing it. The preconditioning of the cabin you should feel. When it switches to cabin (last 15 minutes or so) you will hear the blower fan and the charger will still be feeding power.How can you tell if the car has been preconditioned? Say i set up a departure time for an hour from now, how can I tell?
That's correct. The battery heater requires more power than the ~1kW provided by L1 charging.You're saying I can't precondition the battery if I'm using Level 1 charging? I'm just warming the cabin up?
That certainly shows that the cabin is heating but doesn't necessarily show that the battery is preconditioning.
You can hook up OBD (I have) and watch it but if you hear the recirc pump (get up close) and have heat in the cabin you can be pretty sure it is heating the battery also.That certainly shows that the cabin is heating but doesn't necessarily show that the battery is preconditioning.
There’s a lot going on behind the grill and inside the front wings and the range was as good as it could be?That certainly shows that the cabin is heating but doesn't necessarily show that the battery is preconditioning.
I'd have to see comparable images with battery preconditioning on and off during cabin heating to see if there is a difference.There’s a lot going on behind the grill and inside the front wings and the range was as good as it could be?
I have, there is ?I'd have to see comparable images with battery preconditioning on and off during cabin heating to see if there is a difference.
Did a test last week.I'd have to see comparable images with battery preconditioning on and off during cabin heating to see if there is a difference.
I usually see this about an hour before my departure time:How can you tell if the car has been preconditioned? Say i set up a departure time for an hour from now, how can I tell?
