2026 Velocity Blue GT/CS
Just submitted my update!
jhalkias
Benefit Fund Administrator
Thanks for all the work on this. Very cool. Submitted my data to you.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I didn't realize the link I shared was to a specific revision on the gist.
I should be seeing the vehicle model in the email subject.
Please use this file Fordpass Widget.js (github.com) and press Raw.
I'm sorry for all of this :(
SAM
SAM
Central NJ
Premium MME4X Iconic Silver
Will do later today. I’m at the dealer right now trying to get the TSB 21-2310 done. PowerUp 1.7.1 has been stuck for a couple of months now.
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
Great Script! Waited forever to install, but today I was able to install (the code from thread 18) and it's now in/on the widget screen (I did try it on my home screen, but don't need to see it every time I open, so swipe right works fine)
My issue is for some reason/setting/something I've missed. The widget is the small square instead of the 'medium' rectangle.
If I run the script from scriptable, it asks if I want small/med/large. I tried all three and Medium seems the ideal for the information given.
How do I set up a widget to display the Medium view as default so it goes all the way across the screen?
Do I need to scan the code and look for small/med/large and comment out small, uncomment medium?
Thank you very much for ALL your work with this script. Yesterday I know the horn honked but when I got in the house, I saw on my cameras the mirrors were out! Parking in an Alley makes me check/check/check to be sure it's locked!
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) IMG_4032
Texas-E
2021 Mach-E
When you add the widget, you can scroll to the right (three dots show which size you are on) to get a medium and large format.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) IMG_5895
SAM
SAM
Central NJ
I sent the data. Hope it helps. Sorry for the delay. Thanks.
rodhx
Alabama
Rivian R1T, Lexus IS300 autox/track car.
I made some tweaks to the script... Can those of you that submitted data please update the script using the link above and resubmit?
done!
2021-MMEx-RT1
CA
Yes
Well, I'm an idiot... Didn't even notice the ellipse.
/35+ years of IT support down the drain I tell ya what...
SoriceConsulting
Sal
NJ, USA
sorice.com
2023 GTPE, Rapid Red
IT Consultant
I must have missed an update or am doing something wrong. I also have the widget tool script but if I run it the fore widget goes back to version 1.4, overwriting the 1.5 that I just installed…
SAM
SAM
Central NJ
Yeah, Widget Tool didn't work. Maybe because this isn't an official new version? I had to update the script the old fashioned way.
