- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
yikes!the 12V is at 6V this morning
That is DEAD.
do not even TRY to turn on the vehicle until you charge the 12v overnight ... You MUST get that 12v up to full charge before you attempt to turn on anything else.
- access Frunk, using the external jump points in the front bumper if needed
- remove rear and drivers side Frunk beauty covers
- hook up a charger to 12v connection points for a good overnight charge, or a running vehicle for at least a hour to see if that battery will hold a charge BEFORE you attempt to turn on, shift to 'tow mode', or move the vehicle.
- worst case emergency, drop a full size 12v battery in the frunk, and jumper to connection points to provide power the 12v system for towing so you can get in/out of tow mode.
