Target Charge Level Not to full capacity
JVRK
Austin
Mache AWD
Hello All,
I am new to this forum and I am posting for very first time hoping for some help and support with the issue I am currently experiencing.
I drive Red 2021 MachE, AWD, Premium model with Extended Battery Range.
Drove: 18K plus miles.
Issue:
My vehicle is not getting charged to full capacity of 270miles or at minimum 250miles since purchase.
Below is the picture for reference showing the details of est. distance to empty and rate its charging at 100% and 80%.
The vehicle has been taken to dealer couple of times, but I do not see any fix done. And also I am having continues amber light on my charger.
Its very concerning for me and not able to use the vehicle on daily commute to work.
Any help on this issue will be appreciated.
Ford Mustang Mach-E Target Charge Level Not to full capacity Estimated Miles at 100%
Ford Mustang Mach-E Target Charge Level Not to full capacity Estimated Miles at 80%
Ford Mustang Mach-E Target Charge Level Not to full capacity Charger Amber Light
JCHLi
What's the issue? It's not charging to 100% or are you asking why the range fluctuates and isn't exactly the EPA range?
If it's the latter, the EPA range is a controlled test and actual range isn't very controlled. Speed and temperature are major impacts on actual range
Also, the estimate is just that, an estimate.
bshaw
Boston, MA
Are you charging using a standard 120V outlet?
How many miles is your commute each way?
JVRK
Austin
Mache AWD
-I was getting 200 miles estimate when charged to 80% very consistently, and now after a recent software update I don't see the same estimated miles or even close to what was previous.
- I am using 30amp 220V outlet
That update both reset the driving history and provided a more accurate estimate.
You should be using a higher amperage outlet.
JCHLi
What are you actually getting? Has that changed? If you drive from 80% down to 30%, what was the actual trip mileage
ripperAZ
Ripper
AZ DESERT
I noticed nothing wrong with your scenario. Range is determined by many variables. Don’t let that highly inaccurate variable estimate bother you. It’s unlikely you’ll never achieve the EPA range except under near perfect conditions.
read the last year Of posts and you’ll find many people grappling with the same issue …..it is what it is. Driving conditions in weather definitely lower your range almost immediately. The way you drive also lowers it.
bshaw
Boston, MA
You can't use the Ford Mobile Charger on an outlet with a 30A breaker. That might be why your charger is going to an amber light, although I expect it would trip the breaker before the charger shows the fault light.
Unless your commute is 150+ miles each way (every day), I don't see how your current setup is not adequate for reliably getting you there and back with enough time to charge up by the next morning?
GuliblGuy
Justin
North Tustin, CA
Eruption Green 2025 GT Mach E
The Ford charger pulls 32 amps and is not adjustable. At minimum it needs to be on a 40 amp circuit.
Ford Motor Company
Official Ford Account
Hello All,
Issue:
Hi there! Can you send us a PM with your VIN and Ford dealership information? I’d be happy to look into this Mach-E charging concern on my end.
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Hello,
Don't trust the GOM. It's completely inaccurate, and tends on the side to make sure you never run out of juice and end up stranded if you use it as a guide. Do the math, reset your trip calculator on the car during your coldest commute, review your m/kwh at the end, then divide total miles of commute by this. That is how many kWh you expend during one way. Multiply times 2. Is this more than your usable battery pack (88kw, I think?). If it is less, then you can make it on a single 100 percent charge.
Hello,
THIS. It has nothing to do with your charger or a defect in the car.
The displayed range before you drive anywhere is an estimate, and a conservative one. It is computed using an algorithm that attempts to tell how/where/under what conditions you are going to drive. That algorithm is intentionally conservative in the same way that gas gauges intentionally show "Empty" when there's still a gallon of gas left.
JUST LIKE IN A GAS POWERED CAR the ACTUAL range you will achieve depends on conditions (temp/rain/snow/strong headwinds), how fast you drive, and elevation changes. The difference is that no one pays attention to the range estimate in a gas car.
This is one of the MANY deeper explanations: https://www.macheforum.com/site/posts/322557/
Cm12
2021 Mach E Premium
If you’re using a 32 amp charger on a 30 amp outlet, you could have a problem. For one, it’s a massive fire risk because the Ford charger only knows to pull 32 amps. If it’s a continuous load, like charging a car, it actually needs to be a 40 amp outlet. If your charger is continuously trying to pull more power than your circuitry can actually deliver, perhaps that’s causing a problem.
JVRK
Austin
Mache AWD
I drive 120 miles every day, and I charge everyday from 7pm (night) to 6am (next day morning).
My current rate of charging(mil/kWh) is very low, its around1.9-2.1 mil/kWh; suppose to be at minimum 2.8 or greater mil/kWh to get 248-270 miles range.
Is there any thing that can be done improve mil/kWh charging rate.
JCHLi
Increase your amperage. W = AV, so if you are plugged into a 30 amp 220 V circuit you could theoretically get 6600 W or 6.6 kW per hour. If you change 11 hours you'll get theoretically 72.6 kW, the full battery is 88kW.... So there is that.
Bump it to 32 amps and get 77 kW, get a higher rate EVSE and charge at 40 amps and max out within 11 hours.
Reactions: OWG
