dreKion
Alfonso
Spain
Mach E AWD ER+
This is the one I used initially. It will fail on the CMR updates if you ever get one. This is one of the ones that report corrupted data back to Ford also
Yes, I had problems with CMR, but it was not because of VCI. It also failed with the original adapter from my Ford dealer.
2 weeks later, I was able to do it without problem.
kennelh
Louise and Ken
Northern California
Unfortunately, I highly doubt that is the case. The IPMA update you are showing has everything needed for BC 1.4 "hidden" inside of, but Ford did not include the config to activate the features. In addition to that, for any vehicle like yours that has BC 1.0, there is no option in the APIM to turn on lane change assist, predictive speed, or auto lane repositioning, so you would most likely need an APIM update, too. It goes beyond my scope of knowledge if there is a way for Ford get the config needed for BC 1.4 to work to the IPMA without yet another IPMA update.
So are you saying that if those of us on BC 1.0 update just the IPMA, we would actually lose functionality until the APIM update appears?
rugedraw
Javier
Miami, FL
Auto Sales
No, not at all. Plenty of people have already installed the new IPMA update.
Mike G
N. AL, USA
Mike, that IPMA update alone took almost 3 hours with all the pumps and fans running continuously. You definitely need the power supply hooked up on that one! Did your's take that long? Also, my SOBMD still hasn't cleared since last week either and I tried again today but it's still there.
My IPMA took 2-3/4 hrs start to finish. PSCM took 5 mins. And that SOBDM that wouldn't clear for me previously, was replaced by a full set of powertrain updates that arrived on the same day with the IPMA and PSCM...and those all cleared afterward. So I guess I'm good now.
ProximusAl
UK
Mach-E - SR-AWD - Star White
I've just done all the powertrain updates on mine, and did not get any of them stuck in FDRS.
I did the PSCM which is done, and is currently churning through IPMA.
I can see it's currently pulling 40A from my supply....Thank goodness I bought a 50A supply :)
Just started the IPMA on a VCM 3 so I guess I have a couple of hours to wait......
ProximusAl
UK
@Mike G So Mike, this might be an interesting one for you to check....You should still have my VIN from a PM earlier I hope.
My IPMA fully updated in 32 minutes.......(I use a genuine VCM 3)
Let me know if you don't have my VIN, but have a look in FDRS....
I don't have the eye nanny (no BC), so maybe thats it?
PS: I have a permanent DTC for the reversing camera....getting that looked at Thursday...
ProximusAl
UK
I also now get a weird error when trying to clear DTC's from the powertrain updates.
It comes up with a message about refreshing the tests for SOBDM...e.tc, but refresh does nothing....
I just continued without refresh and cleared...
Mike G
N. AL, USA
My FDRS is being bold right now and not letting me view session histories...even for my own vehicles ("Invalid Token, Unauthorized User").
I can see that your available list is now empty. So that's good. I also had a SOBDM that wouldn't clear about two weeks ago....until another set of powertrain updates came along and after those were done things were back to normal.
IPMA goes much faster on a genuine VCM 3 than a Mongoose cable. VCM 3 has faster chips.
My SOBDM cleared today however I seem to be missing the 1-Pedal drive option in all drive modes or has that been gone and I never noticed? 1-Pedal is working, just no option to turn off unless I select Undridle Extended. I only drive with it on but wanted to mention the option’s not there.
bshaw
Boston, MA
Tiny question that is off topic, but so many knowledgeable people on here and it’s the best place to ask.
I just put in an order for a 2024 Aviator (wife’s car), I was waiting for that platform to get onto sync 4, but I guess they deferred for reasons.
Question : Is the FDRS subscription any use on a sync 3 vehicle? Or no, that’s just the MachE / lightning and future Ford platforms that can receive updates via FDRS?
Thank you.
Eric_C_Boston
Eric
North Shore, MA, USA
Retired Software Engineer
I did the powertrain and other updates today on my 2021 Job 1 RWD ER. The PSCM and IPMA were linked together. Everything cleared. IPMA took over 2 hours. Since PowerUp 7.0.0 or 7.0.1? has a two hour inhibit, I wonder if it is the IPMA update.
Code:
IPMA
DAO1 Assembly    LJ8T-14G647-FT  -> PJ8T-14G647-FYA
F10A ECU_Config  LJ8T-14H106-ADP -> LJ8T-14H106-EDE
F120 Strategy    ML3T-14H102-MDM -> PJ6T-14H102-MDF
F121 Strategy    NL1T-14H102-SBD -> PJ8T-14H102-SBH
F122 Strategy    ML3T-14H102-GAP -> PJ8T-14H102-GAJ
F124 Calib       ML3T-14H103-AAJ -> PJ6T-14H103-AAK
F125 Calib       LJ8T-14H103-ABP -> PJ8T-14H103-ABM
F127 Calib       ML3T-14H103-GAM -> PJ6T-14H103-GAG
F16B ECU_Config  PJ6T-14H103-GAG -> LJ8T-14H310-EAG
F188 Strategy    ML3T-14H102-ABS -> RJ6T-14H102-ACJ
F1DC Calib       LJ8T-14H103-GBF -> PJ8T-14H103-GBJ
I notice the ECU Programming Spec went from 06 to 07 and ECU Diagnostic Spec went from 04 to 05.
PSCM
DAO1 Assembly    LJ9C-3F964-XBB  -> LJ9C-3F964-XCA
F10A ECU_Config  LJ9C-14D007-AAV -> LJ9C-14D007-AAX
F124 Calib       LJ9C-14D004-DAB -> LJ9C-14D004-GAA
F188 Strategy    LJ9C-14D003-DB  -> LJ9C-14D003-GA
PCM
DAO1 Assembly    MJ98-12A650-BDS -> MJ98-12A650-BDU
F188 Strategy    MJ98-14C204-BDS -> MJ98-14C204-BDU
SOBDM
DAO1 Assembly    LJ98-10B689-AZ  -> LJ98-10B689-RA
F124 Calib       PK48-14F477-GA  -> LJ98-14F477-AY
F188 Strategy    PK48-14F476-FA  -> LJ98-14F476-AY
BECM
DAO1 Assembly    NJ98-10B687-BJ  -> NJ98-10B687-BK
F188 Strategy    NJ98-14C197-BJ  -> NJ98-14C197-BK
SOBDMC
DAO1 Assembly    NJ98-7P120-SH   -> NJ98-7P120-SJ
F188 Strategy    NJ98-14G069-SH  -> NJ98-14G069-SJ
Mark Hassa
New Westminster, BC
2024 Grabber Blue GT
Government Food Inspector
Thank you.
FDRS works for I think 2019 and above Ford cars. So Explorer, F150, Escape etc have modules to update just like the Mach E
