UK Customers
James III
James
United Kingdom
2021 (build1) Mach-e AWD EXT (iconic silver)
Developer
Hi Tony just completed a trip to Edinburgh from Lincolnshire. 3 Sessions of Fast DC Charging. No FP App does does not show charge rate.
Nevertheless it is always continuously onscreen on every DC charger.
Tesla Supercharger 350kW gave me 85kW when only car there. 10C from 15% to 70% @. £0.54 kW But 2 chargers failed to connect. Flashing Red LEDS at charge port. Best rate was new GRIDServe on A1M outside of Leeds 138Kw. £0.66kw. Again 1st charger failed with same red LEDs.
SteveUk
Warrington
Mustang Mache with crap keys
Looks good and I’d consider it if somebody wrote off the ‘Stang which is probably the only way I’d change it as I decided to run it into the ground, but if the Explorer’s “range could give you 305 miles” is anything like the MME’s “range could give you 379 miles” the explorer just won’t do, and with a seats-down boot smaller than the ‘Stang’s by 20litres proves the ‘Stang’s more of a useful motor than a poncy one and I’m really not sure all this will go in to the Explorer as it really must………….
That's because the explorer is mostly non Ford parts and more Audi/VW etc
Teslaeata
Nottingham, England, UK
Good point, very well put? Can’t work with anything less than ‘Stang offers. Long live the ‘Stang! Although coming up 54,000 miles, not sure how long “life” for big red may be??‍♂
Dermot Vermin
Essex
SRD Black
You need to get some miles in, I'm nudging 52000 and have got a couple of big trips coming up!!
SteveUk
Warrington
we just don't know what will go first!
The motor or the battery !
It's the undiscovered country
Teslaeata
Nah, no worries, have faith my child, context is important, “the battery” is 94 separate cells which are unlikely to all fail together and each of which can be swapped out individually or as an array in the unlikely event they start to fail. Motors? Well, they’re not a major part such as a dodgy ICE engine (some model Chelsea tractor engines have barely made it out the factory before failing), nasty German intake manifolds catching fire if their main fuse supply don’t BBQ their cars first etc, nor will we suffer from unreliable DM flywheel failures, malfunctioning of temperamental transmissions which our cars don’t have, the brakes just don’t wear so I’m more than happy to take my chances. Just done a state of health check on the battery at full charge and there are no real dramas in there yet……..
Ford Mustang Mach-E UK Customers IMG_0053
Teslaeata
Ooooh, catching me up, DV! I’ll give you a chance, only got c300 miles planned this coming week, Donny & back 3 days for the Level 4 BEV Technicians course. The Pony’ll barely break into a gallop ?
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I’m guessing then that maybe both the FordPass version on your phone and certain car modules need to be at a certain software version for this to work effectively. While I’m sorry to hear it’s not working for you I can confirm that while at an IONITY station in Milton Keynes yesterday it showed the data just fine….
Ford Mustang Mach-E UK Customers IMG_2462
Ford Mustang Mach-E UK Customers IMG_2464
Teslaeata
WD, did you reset driving history to get 282 miles at 73%?
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I didn't initiate it - but it did get reset last week during some FDRS updates :)
Teslaeata
Rascal, you? You always send your range out after resetting driving style sparking range envy?
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Does this calm your range envy? ? This is after several hours of heavy footed “I’ve spent all afternoon in IKEA and I just want to get home” driving LOL
Mind you if you’re carrying all that stuff in your last pic in your car I’m not surprised your range is a bit lower :eek:
Ford Mustang Mach-E UK Customers IMG_2469
Edge2MME
Lorenzo
Kent
Mach-E GT
Looks like Ford UK have updated the information on Blue Cruise for UK https://www.ford.co.uk/technology/driving-assistance/ford-bluecruise 90day free trial and 17.99 per month after. No joy for my First Edition I guess.
    Available in Great Britain only (excluding Northern Ireland). Available on Mustang Mach-E models built after 3rd November 2022.
    Driver’s eyes must remain on the road ahead to enable safe use of Ford BlueCruise hands-free driving. It remains the driver’s responsibility to ensure safe driving at all times. Available on Mustang Mach-E models built after 3rd November 2022.
  • Ford BlueCruise subscription will auto-renew and you will be charged at the end of the 90-day period unless manually cancelled.
    Enable automatic updates for the latest routes.
    Must be switched on in settings to enable Ford BlueCruise.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I’m furious !
Only available for 2023 build cars onward ?
Ford,,,, you are disappointing me, again and again..
It could just be a very badly worded press release.
It might be that the 2023’s have the required software versions to run it now from the factory, whereas older models will require software updates that are yet to come to activate it.
