UK Customers
Teslaeata
Nottingham, England, UK
Swapped mine for Michelin Crossclimate 2 all round, the difference in grip and handling is very noticeable...in fact, it's not as fun now I'm not losing the back on the slightest corner. Not sure if there has been a drop in range as its been cold and the range is kaput! Once it gets warmer then I'll be able to tell.
I’m nearly due a set of tyres, be interesting to see how the wear goes on the Mich’s, better grip’s usually a trade-off against wear. Not sure there are tyres special for EVs, so long as they’re the XL ones for the weight, the car’s not mine……….although………..
Mustang_Simon
Simon
Oxford, UK
Mustang. Mach E. SR RWD Job1
Glad it’s not just me…. I’ve just replaced my Continental Premium Contacts after 18.5k miles. Have put a brand new set of Premium Contacts and the rear grip is still not great. Swapping to the Michelins sounds a good plan if you can.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
I now have the rear washer fault Wonky had! The exact same issue, it sprays into the boot vent!
Oh no - was it the result of recent dealership work or has it just popped off on its own?
SteveUk
Warrington
Mustang Mache with crap keys
It appears to have started out of the blue as it hasn't been into the dealers for months!
Teslaeata
Go on???????
Go on then, WD, spill the beans pls and tell me how you get this up on screen………
Just had a sneaky peek at battery health, the health of each cell is pretty consistent with the rest so no apparent dramas in there……….
Ford Mustang Mach-E UK Customers 6464486A-A4E3-45FD-974A-2E18803B0126
Dermot Vermin
Essex
SRD Black
When you had this, was it easy to spot? My rear wiper is working but no water and no pump sound, wondering if it's this but I can't see of smell any wiper fluid?
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Yes it was easy to spot as I had a bubbly soapy froth coming from the boot side vent on the passenger side. I could hear the pump running but no water appeared on the rear screen.
From what you said in your post you say you can’t hear the pump running? That could indicate a fuse has blown rather than a hose disconnection.
Lucky luke
Luc
Belgium
Mach-E Select RWD
Sales
I have the same problem. Does anyone know what fuse it could be and where it is located (frunk or under passenger seat)? Thanks.
Edit: rear fog light and reverse light does not work either. Could be the same fuse.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Bad news is Rear Window Washer Pump fuse is located in the under hood fuse box (requires frunk removal to access it)
If you’re feeling adventurous it’s fuse location 81 - 10A fuse
Ford Mustang Mach-E UK Customers 40F8FA92-7133-4999-BBAF-6EDAE572DCC1
Dermot Vermin
Essex
SRD Black
Looks like mines going in to the Dealer then..... hopefully it'll take weeks and I'll get to drive an ICE loaner!!!
Jonno21
Derby, UK
A couple of missed opportunities by Ford. One hinged access panel for fusebox and one for the 12v battery connectors. No frunk removal then. My existing frunk panels have looseness and gaps as they've been taken off and put on again several times for dealer software updates with access to keep the 12v battery charged during the process.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
Totally agree.
Within the first week of ownership I modded my frunk panels to provide access to the 12V jump points for when I install software updates. As a result my panels have been removed just the once.
I dread the first time it has to go to a dealership and some @$%* technician gets his/her hands on it ?
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
Totally agree.
I was thinking of doing the same, but luckily I have a dealer whose technicians take pride in their work and are careful with customers cars. Mine has been in a few times since I got it and so far, ? ?, I have not had any issues with loose panels.
