- Steve
- Mar 23, 2021
- Bay Area, CA
- 2024 MME GT with Performance Upgrade, 1979 Fire-Am, 1972 K/5 Blazer
- Engineering
I vote DIY. ??I'm fairly sure it won't fit on my Norco floor jack. I took a spin out to Harbor Freight in Manassas yesterday to check out the spreader and give the blue cruise another test run on 66. The BC works fine on my car, but not sure it's worth buying when trial is up in a few weeks. HF didn't have a spreader in a box we could open to check the connector bolt. I volunteered if they had a hex wrench the right size I could pop the bolt out of the display model and compare it to the bolt from my Norco. That was a no fly zone at HF. Go figure. I said I'd put it back together. I did call HF CS and was told the connector bolt is 1"OD, 4" long, and 8 T/I pitch. I have a metric pitch gauge and measured the Norco bolt at 1.5mm and major diameter of threads at what seems a kind of odd figure of about 23.5mm, of course I can hardly read the markings on my caliper with or without glasses. Maybe it's time to go digital ... Norco confirmed their sizes are metric. So, there you have it ... either I lift one corner at a time or make a DYI spreader.
