Ambient Light Missing in Settings
  • Thread starter Deleted member 3663
  • Start date
  • Watchers 5
Deleted member 3663
Guest
Is there a way for an end-user (me) to edit the AsBuilt data?
agoldman
Charleston, SC
something is definitely weird about this. Almost like it in some sort of locked mode. Update us when they figure it out.
GoGoGadgetMachE
in theory you could do this yourself with an OBD-II dongle and FORscan or something but honestly I'd just have your dealer do it unless the earlier part of this sentence is something you're 100% comfortable with and understand. shouldn't take too long for your dealer. (*)
(*) "shouldn't" is a key word (**)
(**) and yes you shouldn't have to deal with this at all
Deleted member 3663
Guest
Thanks. I haven't seen any results showing FORscan working for the Mach-E (in BETA), so doesn't appear to be an option.. unless I just couldn't find the answer. I sent an email off to my dealer. Thanks for the reply.
buffasnow
Buffalo, NY
Grabber Blue FE, 85 Mustang GT (pasturized)
Sounds to me like your car may have gotten the wrong AsBuilt data programmed into it. This tells sync what features your car has or doesn't have. If you edit that you can enable things that weren't optioned on your car, or disable them.
So if the Selects do not have ambient lighting, is it possible that this car has (at least partly) Select software? I wonder what else a Select does not have that the 4X's have that the OP could look for as another clue?
DanCoon
Daniel
Elk Grove, California
Mustang Mach-E Premium
Government
Maybe they installed the wrong software package in your car?? Like perhaps the one for a model that doesn't have ambient lighting?
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
If its anything like older vehicles, The software is the same for all cars. The AsBuilt data is basically a configuration file that tells the computer what the car is, and what options are installed.
This is why you can make older sync units show the Lincoln theme, or enable software features that aren't available in your car, or add on hardware and enable the menu options for it.
SteelMach
2021 Mustang Mach-E
Yeah it should essentially be an on/off flag in the configuration file, the actual "software" for that menu should be in every car but only displayed when "HasAmbientLight=Yes" (making that up) or whatever is set in the config.
benk016
Tulsa, Oklahoma
You can edit asbuilt data. However, the problem is that no one knows what any of the values are to change. There are a ton more values on this car than any I've had before.
This is an example of what the data looks like:
Ford Mustang Mach-E Ambient Light Missing in Settings 1617919304289
Deleted member 3663
Guest
This is now resolved.
Ford rebuilt the AsBuilt data for my car. A tech at Ford today simply flashed my vehicle with the file he received from Ford, took a few minutes. No settings were lost.
I now can see the Ambient Light settings.
Thanks to @benk016 (and others) as his suggestion I passed onto the dealer, and the dealer got hold of Ford with this info about the AsBuilt needing to be fixed, which led to Ford fixing the issue.
Stouff
Lara
Whittier, CA
2021 MACH-E
No. Voice control is the last on the list, nothing below that.
I have the same issue - did you ever find a fix to it? Did you go back to the dealership to get an update? It say that I am updated, but still don’t see the ambient lighting under voice control!
The solution was detailed in the post right before yours. Just to confirm, which model is your MME?
cleave
cleave
UK
Ford Mustang mache
civil servant
picked up my new car here in the Uk and my ambient light button is missing - any ideas
cleave
cleave
UK
Ford Mustang mache
civil servant
did you get this sorted
Which trim and options do you have? Not all have ambient lighting. I'm not positive, but I think only AWD models have ambient lighting in the UK.
You could raise the center armrest and look for a small LED near its pivot point. This is probably only present when equipped with ambient lighting.
