Are other EVs this bad?
Blue highway
Oregon
Mach E Premium SR RWD
Oh yeah, they've still got $billions sunk into Blue Oval City (TN/KY) and Blue Oval Battery Park (MI). They'll be using those cells for a lot more than hybrids. And of course there's the skunkworks team *trying* to develop low cost EVs. And the existing MME/Lightning/eTransit lines that are still going. (Plus a bit more going in Europe.) This isn't an all-or-nothing thing, just a less-than-previously-planned thing. With more shift to hybrids this decade than previously planned.
BTW
You just said something that caught my attention.
The message from the app just said the battery was being drained - likely from 3rd party after market device. Then the car went dead as far as the app is concerned But it didn’t say which battery.
If it was just the 12v battery, what are the ramifications? Would that cause the app to not be able to “see” the car? How would I get that 12v battery recharged?
I’m positive the car was off - it loudly alerts when you open the door and the car is still on. I wasn’t in a rush (this time). And it initially showed a charging error on the app.
Thanks for the 12v insight!!!
all EVs have tiny 12v (or 16v) batteries... you can not leave things like a dashcam on or you will drain the 12v battery quickly.
While it is something that has not been widely reported on, it is 100% feasible to plug in to charge and have the 12v die. Two things I have personally seen are bad chargers and not fully plugging in the charge handle. Both will keep the vehicle awake without charging and thus kill the 12v.
So one of these is a problem with charging hardware and the other is operator error. Neither is a sign the vehicle is terrible.
Broken gas nozzles and failing to insert a gas nozzle properly has two likely results:
1. Gas tank doesn’t fill
2. Gas spills all over the ground (and maybe people)
Neither is a reason to ask if all gas vehicles are this bad.
Gimme_my_MME
Dearborn
Agree. He said his initial post was made in frustration, think we can all relate.
astrorob
rob
bay area
24GT, plug-in prius, 99 MBZ C43
isn’t there a CSP open and at least one TSB about modules failing to sleep and potentially draining the 12V battery? the CSP requires an SOBDM update so it seems like it could be related to L2 charging. possibly OP got bit by one of these issues.
shark
Texas
Mach E GT
I won’t do Tesla- I don’t need the public blow-back.
LMFAO, you have to be trolling, right? Only an unhinged lunatic would give you "blow-back" based on what car you drive.
WJD
Tucson AZ
2021 Mach E
For what it's worth, I've had my Mach-e for over 3 years and have had no problems. On longer trips I do drive in the granny lane, it's remarkable how that improves the range. I hope your experience improves.
Sikkun
2023 Mach E
Not like German cars were being driven around proudly in America during WWII….
Face of your company does enough bad things there will be people judging you for supporting them. And they won’t just be “unhinged lunatics”.
Fordman
Frank
Austin Texas
2016 FORD EDGE, 1998 FORD EXPEDITION
Retired Ford Dealer
I was so excited to buy my first EV in December - a new 2024 extended range Mach E Premium!
it’s been downhill from there - broken mobile charger that ford won’t replace, range under 200 miles, and getting stranded at the airport because the public charger provided drained the battery instead of charging it.
I’m definitely done with Ford, but I’m wondering if other EVs have these same issues. Anyone have any experience with Hyundai or any other EV makers? I won’t do Tesla- I don’t need the public blow-back.
I’m wondering if I should give another EV model a try, or just go back to ICE cars because maybe EV technology hasn’t come far enough to produce an every-day reliable car. Thoughts?
Two and half years and not one single problem.
Jack Roberts
Atlanta
Mach e GT
If you think this is problems you need to go back to ICE
MachE1977
SoCal
25 MME/24 CTR/23 Golf R
You need a Tesla. It's the beginners EV. After you are done with it you can move up to the Big Leagues like with the MachE. Ionic and so on......
4wheeldog
7200' elevation New Messico
2024 Premium AWD Extended range
Retired a long time
Well the OP was due back at the airport and his MME late last night. We are waiting with bated breath to find out what actually happened?
There’s a TSB for 2024 models. I believe (someone correct me if I am wrong) the CSPs were taken care of before the 2024 Job2 cars were built. I know that my 2024 Job2 only has the TSB open. ?‍♂?
PilotMark
2022 Mach E Extended, Mini Moke, FRS, Prius, FJR, 1966 Shelby Mustang
To feel better you should get an ice car. I would even suggest a hybrid. Stay with what you know.
astrorob
rob
bay area
well unless ford made a mistake, the CSP applies to my 24GT. i just had it applied at the dealer. should have asked for an FDRS dump before whatever they did.
the doorjamb sticker on my 24 says it was manufactured in 11/24, so i assume that must be job2.
Huh. Mine is 2 months older than yours. I dunno about the CSP then. ?‍♂?
