Best Tire for the Mach E?
The best tire is dependent on your criteria. I wanted lots of performance and decent tread life. That led me to all-season 275 UHPs. That led me to 9-1/2” rims. My daily commute sucks down roughly 10%-12% of my battery (round trip), so I care not a bit about range. Everyone has their own criteria. ??
Exactly. Was going to mention the same thing. There is NO best tire for the Mach-E. It all depends on what you want in a tire. My top criteria is performance so that basically means I don't care about anything else, especially tread wear and range. I tried to make UHP All Season's work for my winter months and even though we don't get much snow where I live, it was limiting me to places I wanted to go. I used to own F-150 4WD's the last 40+ years and would use those for winter months but sold my last one when I bought the GTPE.
I've always run Michelin Pilot Sport 4S's the last 8 years on my cars. It's my favorite performance tire hands down. Next month I'm getting Michelin's replacement for the PS4S which is the Pilot Sport S5 on a new set of wheels. I decided to use my current set of wheels for Performance Winter tires and purchased Michelin's Pilot Alpin 5's. Had a chance to use them last weekend when we had a freak snowy day (April 13th) and they worked out extremely well.
Ford Mustang Mach-E Best Tire for the Mach E? IMG_4777
DevSecNetOps, General PITA
Having had some more road time on my RX's on the freeway I gotta say they're actually pretty quiet. I 've been hunting the summer Ion Evo's and they're $100 a tire more than the Conti 06+'s which are my other target tire (and the fact they're readily available and 20+ more milage warrany is a huge plus for me, as if i didn't have bad luck, I wouldn't have luck.)
I think it is possible that both are true. The GT spec tires are mst likely not as efficient as the Primacy A/S tires that came on the Premium model like yours and mine. And I think it likely also that the range reduction may not be as pronounced or as noticeable for people who do not do long range driving exclusively as I do. But my analysis has not changed. I’m still having to stop for power more often than I used to when I drive from one home to the other. I prefer not to stop.
You didn't change the tire size or rims, right? Just the tires, same size but different brand?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
I've had Hankook Ion Evo AS SUV for about 8 months now. Really like them. Quieter and smoother than the factory Michelins.
I had installed red pucks on the jack points before taking the car in to Americas Tire/Discount Tire. I walked out to their shop and told the techs the jack points are in red and then watched to make sure they lifted it at the right spot. They had 4 guys working on it at the same time. the whole process took about 15 minutes (to replace all 4 tires).
Thank you for your business, we greatly appreciate your support. W are glad the store was able to get you taken care of in an efficient manner. 15 minutes for 4 tires is outstanding.
rhougey
Rich
North California
Correct. Same size as original tires mounted on original OEM wheels
Skyman63
Isabella, Mo
2024 Mach e GT, 2019 Ranger 4x4, 2017 C-Max Energi
Retired high school teacher
I’ll throw in my pick of the Pirelli P Zero A/S + 3 tires into the mix. I replaced the Pirelli P Zero + Elects that came with the car with these. The ride very smoothly, are quiet, and I lost no range. I should add I also got new wheels that should have reduced my range if anything. Tire Rack tested the A/S +3’s and they run neck and neck with the Pilot Sport All Seasons and the DWS 06 +. The Tyre Review website had the same findings. The only unknown for me at this point is how the tread life is going to play out.
I am surprised you are measuring a loss. New tires are known to have higher rolling resistance when compared to worn tires near the end of life. I wonder is that has anything to do with it...
rhougey
Rich
North California
Mike, believe me, I have wondered all the same things you are wondering. I didn’t expect range loss at all. Based on other reports on the forum, I expected to love them. Old tires are lighter and I expect have hardened up a bit, so new tires will inherently feel more “plush” and be heavier (more tread), and somewhat less efficient than the old ones at the end (maybe 1 or 2 percent?). But the original tires ran 48,000 miles in 2-1/2 years, and I have never had to stop to top up the battery as often as I do now, even when the car was brand new. I have changed nothing else on the car and the range loss was immediate after installing the new tires. In every other way I like them just fine.
csilvest
Idaho
'24 Rapid Red GT, '16 Mustang GT Conv
IT Administration
Phones are getting smarter about this. iPhones have an optimized charging setting that charges to 80% immediately when plugged in and stops there. Then it resumes charging to 100% based on what time you start your day and unplug the phone, so that the SOC time spent at 100% is minimized.
Interesting - I've been using a similar approach to charging mt '22 GT. I have it set to charge to 85% which it reaches sometime overnight. When I wake up in the morning to a notification that charging is complete, I press the "Charge to 100%" button. When I'm ready to leave a few hours or so later, it has charged up to ninety-something percent, but since I am then driving it right away it doesn't spend as much time at that SOC than if I had set it to charge that high automatically.
Even if it doesn't make a large difference in battery life, even a small difference will be worth it as it's a routine that was easy to get used to.
Have you checked your HVB SoH? Mine has declined to 90.5%, which is a 10% loss in range. If yours has decreased similarly, it could explain some of it. And maybe the new tire thing explains the rest?
I see just about 92% SOH after 3 yrs/40k. (just a tidbit of datapoints) and my 7yr old FFE's battery shows 87% after being abused for 7yrs/100% charges/outsize in Phx all year and 65k on it.
rhougey
Rich
North California
I know others have talked about checking HVB state of health. I’ve never really considered checking it. Consequently, I haven’t looked into how I would do that. I do have the (OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows), along with the OBD link app, but have never plugged it into this car. Admittedly, I have limited experience with it. Could I check SOH with that or do I need FDRS or dealer to do that?
thenew3
Central Coast CA
BMW X7, BMW X3, MME Premium 4X
Just get the carscanner app from the app store.
