Dead MME !
Don_23805
Don
Central VA
Honda Ridgeline, Prem MME DMG AWD Ex Batt
Did you by chance test the voltage from cig lighter for pwr on and pwr off. That will be the first thing I do if I get the warning... from any place about charge issue. 900 miles seems crazy. Almost like an overhead light was left on...
Didn't check the 12V level. FP message seemed to indicate hat "headlights left on" would affect range, a function of the HVB. Think the problem was leaving the MME plugged in, even though it had fully charged overnight and the 12V charging bug had not been fixed. Never seen the 12V battery, but without needing hundreds of Cranking Amps like ICE, it's probably no bigger than on my lawn mower battery.
Don_23805
Don
Central VA
Unfortunately you are probably correct, especially in cold locations and if the car isn't driven more than a couple of times a week most of the time.
I would expect that with 90 kwh in the HVB as a charging reserve for the 12V that it would stay charged for a long time.
Don_23805
Don
Central VA
Maybe both have an issue and so the HVB is dragging the 12v down. I do hope you get resolve. I have 190 miles (since 12/8)...
The dragging down should be the 12V (slowly) dragging down the HVB since that is its charging source. Still suspect that the "12V not charging when charging cable is plugged in" bug didn't get fixed.
Don_23805
Don
Central VA
I would be afraid of putting this car on a transport to Florida from NY for example and it might not start when they try to deliver it.
My MME arrived at dealer day before Xgiving. They said it was only half charged and they would top it off (which would have delayed delivery a day). I said I'd take it at current charge level since I'm only 25 miles away, and have had charger ready to go since April ;=)
I think if you put it on the Amtrak Autotrain, fully charged, there would be plenty of juice to keep the 12V charged for that trip
dixiekidd88
Joey
East Bay Area, California
www.walnutcreekford.com
21 Prem XAWD and 25 Prem XAWD (Previous)23 Prem XRWD
Still waiting for a diagnosis from the dealership ours was towed to after shutting down on the interstate with no restart and dead 12v. The tech that looked at it and started on it 'called out sick' yesterday and no update today.... This was the codes shown right before it shut down, just at a loss of words now
Ford Mustang Mach-E Dead MME ! sfdsafd
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
Maybe the car has Covid
Crilly
Dale
Hartland, Wi
A deep cycle battery is less likely to short out when draining and recharging. I know sealed batteries can short out. (Not hold a charge)
Mawby
Markus
Central California
1933 Ford Speedstar Roadster, 2021 Mache CA RT1
Business Owner
True. Could also just be a bad 12v battery period. They fail too. Why 900 miles to kill it. Laptops sometimes are troubled for 30 days but if you use it 1x month. You just went past the 1 year warranty.
Don_23805
Don
Central VA
My dealer seemed to have gotten over their lack of personnel (perhaps with some out of department pressure) and emailed that it was fixed and they would deliver it shortly. They said the problem was a bad cell in the 12V battery. Sounds too familiar.
All that speculation and it was just a bad battery?
Oh well, at least it’s a super easy fix.
Don_23805
Don
Central VA
Not sure that's all of it. Going to install my BT OBD reader today and also check out the recovery connectors.
Shayne
Northern Ontario Canada
2021 MME4x Prem
A fob in your pocket and a huge deep cycle RV battery with jumpers in the frunk. Don't leave home without them ;). Maybe I do need to take out my dividers from the frunk after all; just to get my spare battery in there ?. Should not laugh too loud as a spare 12V and jumpers on a trip has now crossed my mind. Maybe the ACDelco and keep it on a maintainer.
It appears to me to resemble the motherboards cmos battery but unlike the MB it is rechargeable and if it is charged and maintain then it should last a long time. The MB silver dollar cmos batteries last years and you can't charge those. They die quicker if the machine is not ran much but as noted you can not charge them.
My guess not the battery size or type and possibly defective 12V's (or a component) or a logic problem as all the hardware and power it needs to maintain the 12V is sitting right there. If I can do it with a charger plugged into 120V when an ICE is not running I should be able to when plugged into in an EV charging port. Got to be a trickle charger logic in there somewhere? Don't think the size of the cmos battery would be a big deal if healthy and maintained.
I am sitting in that position too. Try it and hope it does not die for the 3rd time. A least so far I have dodged the bullet that @dixiekidd88 caught. Didn't like hearing that story.
The more info the better. ?
Ford Motor Company
Official Ford Account
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this on my end.
Rjm
Rich
2021 Infinite Blue Mach E Premium
Retired- probably oldest Mach E owner in the US- 83 yrs
Lately I have been getting this screen when I start my Mach E. 3 out of the last 4 starts. Has anyone else seen this or can you offer any insight. Could the 12 volt battery be having problems
Ford Mustang Mach-E Dead MME ! 28C230E0-63A1-42C0-B4F5-6DC3EB320EC7
