E-Z Pass Transponder problem
JerryF
Jerry
Cary NC
Mustang Mach e
Has anyone had a problem with their E-Z Pass transponder attached to their windshield not being read when they go under a toll reader? If so, how did you solve the problem? If not, where on your windshield do you mount your reader? Is anyone using an externally-mounted transponder? If so, how did you mount it?
SWO
MD, USA
The transponder has to be installed on the dot matrix on either side of the mirror in order to work.
HGxxx
Harish
New york
Fusion energi, mach e premium standard range
This
GreaseMonkey
Chicago, IL
24 Mach-E GT
No issues with the EZ pass transponder and other devices when installed as indicated. I thought it was very thoughtful of Ford to provide that dotted space for installation.
I wish they would address weakness in the embedded garage door opener though. It takes me multiple tries while manipulating the sun shade and ensuring the vehicle is square to the garage door to be able to open it. All the while, pedestrians are crossing in front and behind me. Not a good set up.
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
We had problems with our Homelink working correctly with our Mach-E and Lightning until I positioned the antenna on the opener pointing straight down. Maybe give that a shot.
GreaseMonkey
Chicago, IL
24 Mach-E GT
Thank you! I live in a high rise building, so don’t have the ability to make adjustments. My Prius’ Home Link could open the same garage door from down the street, so it seem to me like the sound deadening coating on the windshield is blocking the Home Link signal too.
That's weird. Mine works from down the block.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
I have mine mounted above my license plate. This, of course, is only an option if you have a front plate or are willing to drill the front of the car. NH requires a front plate so not a big deal for me.
Mine sometimes works from down the block, sometimes not until I’m directly in front of the garage door, and sometimes not at all ?‍♂
DevSecOps
Todd
CISO
I agree. My gate, a LiftMaster and garage door, Chamberlain (same company) both require that I'm basically ramming them down before they'll open. Since I back into the garage I noticed it works better when the garage is behind me. Obviously this doesn't help you any, just an observation.
My Rivian opens both from 1/2 a mile away. So Ford obviously has something wonky with their homelink setup.
Kaplan
Joel
Boca Raton FL
Ford Mach E 2021
Yes, move it to the shaded area either side of the rear view mirror
