jhalkias
Benefit Fund Administrator
Mine seems to be fine now. iPhone 13 Pro Max, iOs 15.5
4.17 Android definitely has issues.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Yes, worked flawlessly for me for 11 months. Last update broke it and this one fixed nothing
Uninstall, reboot and reinstall app. Uninstall and set back up and nothing? Turn conductivity off and on in the car to reset it? Since this a heavy server dependent app and the servers have been found wanting up here it could be a server side problem. Did you contact Ford about your account to make sure nothing is hung there?
What phone do you have ? Restart iphones twice. Android you will need to clear cache and data.
What's the magic in twice?
Logal727
C
If your phone is rooted or jailbroken, don’t expect it to work correctly or get support from Ford for it, which is as it should be.
FP appears to still be at 17.0 for Android, no update available in PlayStore
Marc S
Marc
United States
2021 Select (lease ended) Now 2023 GTPE
Thanks, I had an open case with Ford on this. The last time they called me was actually on the 4th of July. They informed me that they had identified the problem and it would be fixed with this new update. They closed my case. This update did not fix the problem
Shayne
2021 MME4x Prem
Did you try turning the conductivity off and back on in the car settings? Phone connect problem to the car may not be just the phone?
Could be their new authentication that stumped the widget tool a bit? Someone has mention he is getting emails that his password is banned by Ford. Guess you are opening a new case. iPhone 11 no probs here.
mattbostonmache
Matt
Newton, MA
Rav4
These messages started showing up in 4.17 and are still happening in 4.17.1.
and this is after being parked for hours.
this never happened before 4.17.
Ford Mustang Mach-E FordPass 4.17.1 Release 1657142406350
Marc S
Marc
United States
Yes. Toggled all the settings in the car and on the iPhone as well. Was working with a rep from Fordpass.
rachitsh
Rachit
Minneapolis
2022 Mach-E4X CA Route 1
I have the same issue. The only way to get rid of this is to restart the app.
Shayne
2021 MME4x Prem
You will need to let us know how you get it fixed.
Makes you wonder how much of your data plan it will be using when in lock screen. Maybe ransom ware? ;)
JuliaSWMME
Ontario
2023 GTPE Nite Pony
when will we get dark mode for the app? We can have it in the car but not the app. annoying.
