Jim Glass
Tybee Island, GA
2021 Mustang Mach E First Edition, 2019 Audi Q5
Same same. Had to remove/reinstall app. In car (yes sit in car switched on) in an open area. In settings on car reset FordPass key (not full reset) to clear everything related. On phone with reinstalled app set up phone as key. Be sure to follow all instructions especially backup and door codes.
Shayne
Northern Ontario Canada
2021 MME4x Prem
What does this version break? Enquiring minds would like to know. ;)
Then we wait and then read on. I finally got 3.27 working like 90 and then well there you go. ?‍♂ I may enjoy 3.27 for a bit longer. Mine never crashes so not all setups are the same.
woody
CO
forced(as usual via Play Store) 3.28. Dealer button (totally useless) is only change. Not up long enough to experience faults.
jrstinkfish
Scott
Memphis, TN
2021 Mach-E Premium RWD SR Infinite Blue
Overall the user interface is pretty clunky - but that's all I want is to be able to swipe left on the messages to delete them. I know, such a small thing...
I've got a phantom unread message in mine that just won't go away. There is always at least a red "1" indicator there telling me there's an unread message, but there really isn't an unread message. Weird, but I'm just used to it after a few months.
JCHLi
Is the "manage latest alert" option under SecuriAlert new? I don't remember seeing it before.
Also, although my schedule still works, it no longer shows up under scheduler.
Yes. I think it’s new.
Shayne
2021 MME4x Prem
Then one day it just disappears and you miss it ;).
Had this once it usually syncs but start the vehicle change the schedule and then back again (if you want what you had) may speed up the sync? Your car maybe just sleeping and needs waking up? Can't remember been trying so many tweaks pampering this setup. It has personality. It should come back and not too much of a worry I think.
ralcar
Ralf
Sweden
Ford Mach E
Rookie numbers, i have twice as many hidden messages as you!! =)
Terje
Terje
Oslo
Mustang Mach-E LR AWD m/tekno+ Infinity Blue
I have struggled with the ford app with it stopping, closing and the car not finding the key
Now I think I have found a possible solution, so that the app can work in the background without having to open it every time. It also does not seem to have an abnormal amount of current. I have a Samsung S21 +, went into "settings", then to "battery-my-device management", then to "battery" and then to "background usage limit" and finally "apps never in sleep mode". There I removed several apps that I did not use and that did not go to sleep and then I pressed the "+" sign and added the ford app.
Now the key symbol of the ford app is at the top of the phone, and I can now leave it there in the background and it works great. If you have problems with the key on your mobile, try this
J Duce
Jean
Jamaica, NY
2017 Explorer Sport
One thing I noticed yesterday is that my PAAK worked better. Usually, I would get to my driver door and wait a second or 2 for the handshake and the button to light up. Yesterday on two occasions, the car lit up as i approached about 5 to 10 feet away (similar to with the key fob). I think this is the first time it happened. Also, it seemed to oddly turn on faster when approaching the car from the rear on passenger side. I will monitor again over the next few days.
santa fe,nm
www.envirokarma.org
Solar Sales/install
App has used 15% of my battery after three and half hours. Battery drain issue still not fixed for me.
Hello @Ford Motor Company , anyone home?
thanks for noting actual use.....
I doubt I will update until there is progress on this issue specifically.
are you following this Thread @Ford Motor Company?
we want the battery use reduced, and re-connection on approach quicker....
AND specific release notes so we know what's fixed in each release.
santa fe,nm
www.envirokarma.org
Solar Sales/install
considering the difficulty I had installing FordPass initially, I will not be doing an remove/reinstall..... and will only 'update' once I hear that the battery drain issue has been addressed. until then, I'll stick w current release and 'force stop' the app when I'm not driving.
imstriker
Matthew
Indianapolis
Tech
So far, at least, I would say the battery drain is better on my Pixel 5. I turned the background use restrictions back off and re-enabled the PAAK notification. After almost three hours, my phone is only down about 22%. In previous cases, I would have been near dead after three hours. I'm going to give it some time, but it sure is nice to actually walk up to the car and get right in.
Shayne
2021 MME4x Prem
Thanks this type of observation is appreciated. Phone type? Guess it was not lighting up for you much on approach before if you were standing beside the door for 2 seconds. I have found as 3.27 settled down it has start working better also and has been good this past week? Just toke the 1/2 hour to get carplay booting and functioning adequately on that release. Guess i may guinea pig again.
Eraser
2021 Mach-E Premium RWD | SR
Are you saying Fordpass used 22% of your battery after 3 hours? If so, that is crazy high.
I'm on a Pixel 5 as well, yesterday after about 8.5 hours it used 3% of my battery which isn't bad at all. Today is the first full day using PaaK again (left the fob at home). So far so good. Usually I have a hard time getting the door to open first thing in the morning from home. This time I pressed button to open the door, heard the usual clicks when it wakes up, then 2-3 seconds later pressed it again and it worked. Start button worked right after that.
