How Often Do You Charge?
thx10
Missouri
2025 Mustang Mach E GT
Just got my 2025 GT on Saturday. My first EV. It had 98% and just doing daily driving - work and errands. I am currently at 62%.
I will be getting a Level 2 installed soon and will use The 110v until then or a public charger if needed.
how often should I charge or how low should I let the battery go? Again this would be for daily driving. For long trips I will follow what the car tells me
any suggestions appreciated
MattG93
Matt
Dallas Area
2025 Mustang Mach-e GT
Technology Geek
Congrats and welcome!
I'm with RockinVs. I plug in every night, and pretty much any time I am home. I'm still on the 110 as well, hoping to get my L2 installed in a couple weeks - getting my 35-year old home electrical panel replaced on Thursday.
Many threads on this. Plug in when not driving, charge to 90%.
uberpat
Patrick
Joppa, MD
2025 Mustang Mach-E Premium eAWD Ext. Battery
Currently still only have my L1 ford mobile charger to work with for my 2025 MME. I follow the ABC "always be charging" mentality and have the limit set to 85% because I can't commit to 80% or 90% for some reason haha.
YeOldeTraveller
Clark
Ann Arbor, MI, USA
2024 MME Rally
Congrats on the new car.
My Rally is my first EV, and I did most of a year on Level 1 only charging to 70%, but I did plug in any time I was home. I now have Level 2 installed, and I still plug in when I am home with a charge limit of 70%. I only push this when I will be doing a longer than normal trip.
If I get home above 70%, I might not plug in. (I have free Level 2 charging available at work.)
Homer007
Nick
El Cajon
22 MME Premium Ext AWD
Had my car just over 3 years. Charge it nightly up to 90% on a level 2 charger. 100% about once a month due to longer road trips. Battery still seems fine, I've noticed no dip in distance etc...
Due to the upper and lower buffers on the Extended Range battery, 85% indicated is very close to 80% actual SoC, so you done good. 😁🐩
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
I charge to 85% every night. Since you have the GT, you don't need to worry about charging to 100% now and again, other than if you have a longer trip coming up.
The '24-'25 Select and Premium models have the LFP battery, I believe, which should be charged to 100% once a week, or so...
Deleted member 19354
Guest
Whatever percentage you charge to make sure you are using premium electricity. Some of the cheaper blends you may loose power and have some knocks and pings ??. Seriously enjoy your new vehicle!
joebruin77
When my wife drives to and from work, she uses about 10% of the battery. So we set her upper limit to 60% and plug in when she gets home every day. She arrives home with the battery at 50% and it charges each night to 60%.
I saw an Engineering Explained video on EV charging. The expert said, to extend battery life as much as possible, keep your upper limit on the lower end and charge a little bit each day.
That said, the overall difference between doing this and charging to 80% or even 90% is not all that huge. So others believe you should just charge to 80 or 90% and not worry about it.
StevenC56
Steven
Fresno, California
2025 Mach E GT Glacier Gray "Maximus", 2024 Lightning Lariat Avalanche "Rex"
We have both the Mach E and a Lightning. We're retired and don't rack up many miles, so when either one hits 50% I charge them to 90%. If we're going out of town I charge to 100% the night before we leave.
TheRock
Canada
2024 Mach-E Premium AWD with Extended battery
ABC = Always be charging
Charge to 90%. Unless we're leaving for a trip, 100% just before we leave.
DugthePug Dad
Pat
2023 Mach E premium
I’m retired and charge about every 3 weeks or so.
it’s usually from the high to mid 60’s% up to 90%.
