RyZt
San Jose
Mach E4X
Even if they did need 100%, most likely they'd just leave it plugged into the DCFC charger longer, unless they were on a per-minute rate. Most of the EA states have moved to per-kWh now. Plus 12-15 kW (slow as it is for DCFC) is still faster than most L2 (typically 7.6 kW).
If it turns out a lot of people do that, sooner or later, EA will make idle fee kick in at 80%. In my opinion, the sooner the better.
methorian
Roanoke, VA
IT Admin
Just speculation but I am thinking that is wrong. Chances are these early production vehicles are just on "Ford's Account" for whatever amount they are DCFC. Otherwise, how could multiple reviewers check them out before that 250KW ran out? I doubt this car had a 250KW limit of free charging at the DCFC.
Maybe - though I wouldn't be surprised that EA and Ford's agreement just gives 250KW to each Mach-E VIN for free, and that Ford sends pretty much all Mach-E VINs to EA for this offer.
Either way, I just think something funky is setup with the charging curve - will be very interested to see more in depth info, especially once customer cars are delivered.
Could be. My Outlander PHEV actually stops charging completely when it hits 80% on DCFC.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
That is assuming the DCFC doesn't taper more from the 12-15kW down to something less than 7.6kW.
ajmartineau
Washington
2021 Mach-E
Lets look at the charging curve that was posted several months ago and compare to the latest information:
Yes, I posted that months ago. I guess I need to put a watermark on it, lol.
Although I just drew a quick line with my figure over something someone else worked hard to make.
This was based on the information I could find at the time. Some people called me a liar.
  • Like
Reactions: UW2
CarboFE
Minneapolis, MN
Mustang Mach-E FE Carbonized Grey
Typically that is why you find Level-2's nearby DCFC's: Because when you get to the 80% level it is often better to move to a Level-2 as it will charge at the constant rate where the DCFC will continue to taper below what the local Level-2 will deliver (and the local Level-2 will likely cost less than the DCFC for that last 20%).
Yeah this isn't ideal but it works (and you free up the DCFC for someone else).
I shouldn't have to do that. If I pull up to a "fuel pump", I should insert the cord into the receptacle and when the pump says I'm done, I should be able to drive away with a full "tank" of power. Complications like these are why BEV adoption won't go mainstream. It has to be simplified.
JamieGeek
You don't have to do that at all.
If you want to annoy the people in line waiting for the DCFC by sitting there and letting it charge to full then go right ahead.
There is no rule or anything forcing you to do this.
Its just what has been sometimes done to be courteous to the next person waiting for the DCFC.
jhalkias
Benefit Fund Administrator
I actually unplugged from one of the two L2 chargers in a parking garage in my Fusion Energi when a guy pulled up in a bolt and told me he was at 3%. I had plenty of gas and was just enjoying the electrons for paying for my parking.
RyZt
San Jose
Mach E4X
Charge to 80% and leave. 80% is the new "full".
dbsb3233
TimCO
Colorado, USA
True. Although that would surprise me.
Frankly I'm a little surprised EA's high-power chargers even go that low. I'd almost think they'd just shut off and end the charging session if the car tried to limit it below a certain threshold, so no one can tie up the charger at L2-like speeds for hours at a time.
Or maybe they have a time limit?
dbsb3233
TimCO
Colorado, USA
I agree with you that these are the types of complications/annoyances that will slow BEV adoption. Same with dramatic reduction in range where most people will care about range (highway speeds for road trips). And major losses from cold or hot temps. And of course sloooow refueling on the road.
But it is what it is. Many people will accept those compromises to gain the other advantages, while many people will say "no way" and just keep buying ICE, hybrid, or PHEV. I expect PHEV to be quite big this decade for those very reasons. I also expect BEVs to more commonly be going into 2-car households (with a garage) to be paired with an ICE or PHEV.
dbsb3233
TimCO
Colorado, USA
I never really understood why they would even included DCFC capability on a PHEV.
Yeah, it's kinda dumb. There are a couple of charging stations around me that are free, but only Chademo with no Level 2. I used one of those exactly once.
balthisar
SE Michigan
2022 Expedition; 2025 Mach E Rally
Engineer@FoMoCo
When I had my Fusion Energi, I tried to plot a route from SE Michigan to Orlando and back without using gasoline. DCFC would have been really helpful!
Billyk24
William
PA
Your Fusion Energi had an usable 5.6kWh battery pack. Rated for 20-24 miles but significantly less at highway speed. How could anyone drive that distance with such a small battery pack?
