Shayne
Northern Ontario Canada
2021 MME4x Prem
Can not imagine crawling into a M3 and driving that look around for that winter range which is the only time it matters (When heat pumps don't count). What also needs to be noted is there is a 100 KWh pack using 88 in the stang.
Both are just a wee bit better in efficiency compared to ICE. @ 33.4 Kw/gallon I pay 30% less a gallon right now and at 16.0 Kw/100 Km (@benk016 above) it gets over 200 km/gal or 130 mpg. I am getting around 105 mpg. The Rav4 at 40 mpg is not a match and comparing ev's I find is becoming a bit like spitting hairs. Both are green if the charge is. Range is still king not efficiency.
Good to see so many options coming out. Just keeps growing :).
Carsinmyblood
Mitch
Western NC
Self employed
I wonder how the distance/kWh would compare in a short course if they were all weighted the same?
The MX-30 at 13.2kWh/100 and
the VW ID.3 at 13.3kWh/100 compare favorably, but are at the top and bottom making one of the better performers look awful.
Blanked
James
Bluffton, SC
2021 MME FE , 2003 Ford Excursion EB 4x4
Keep in mind, those figures were for the WINTER test. They just did the Summer test last week.
I was about to state the same thing.. that the MME was not #1. But I'm happy to see our MachE-4x in the top5!
Also, just think, if Ford can get their Average Consumption into the 12.2 - 12.4 kWt/100 range like Tesla... then It's a Fight for sure.. the fact that VW is in the 13.3 - 13.5 kWT/100 range with two vehicles is a little concerning for Ford...
just my opinion
pt19713
For
I kinda feel sorry for the ones at the bottom of the list. Seems like scooter ranges.
For Europe, range isn't as important due to the shorter distance they need to drive and public transportation infrastructure if they need to travel longer distances (train).
ARK
Los Angeles
'21 Premium SR AWD
Aerodynamics.
What’s interesting is battery tech seemingly gets all the attention with regard to future range improvements across the industry, but I wonder what exists in the R&D pipeline for improvements in energy use with upcoming motors.
The Fords also don't have heat pumps and are CSUVs. Imagine a low profile electric "real" Mustang with a heat pump.
The Mustang Mach E IS a REAL Mustang. Sigh ?
theo1000
Theo
Shawnee, KS
Mach-E 2021 IB, Audi Etron, Chevy Volt, BMW I3,
The M3 and the MachE are simply not comparable. The M3 is closer to the ID3, really a sub-compact these days, the ID3 is in fact taller. I wonder how driving characteristics affect the efficiency numbers. I know just a subtle change in how I accelerate can make a 5%-10% change in efficiency. The MachE does have a tendency to lunge when you hit the accelerator. Kinda the old ICE mustang feel.
Ford should just build attractive capable cars, don't let some silly range measuring stuff dictate your approach. The Mach-E and the ID4 are more comparable. 15 to 14.5.
ab13
Rav4 Hybrid
I would expect most of it has to do with cost and weight. The efficiency of electrical motors is high, 95%+. In fact the government research labs tests various hybrid and EV drive systems and the efficiency of power coming out of the battery and from the motor is around 95%+ in the best designs.
Improving aerodynamics and weight reduction will result in better improvements than chasing 2 or 3 percent system gains. Of course the electric motor suppliers are going to keep improving, but you could get 5%+ more range from aerodynamics and weight savings.
That is really where the difference is between Tesla and other designs, they reduce weight and have lower aerodynamic drag. That does affect their styling and lack of features (weight). The upcoming Mercedes EQS is going to be among the first to have lower drag Cd than Tesla, so its real world range and efficiency could be higher.
theo1000
Theo
Shawnee, KS
A 20% reduction in battery cost without large weight increase would make all this irrelevant as the Mach-E is demonstrating. All of TSLA scrimping and scraping and lightning macqueening means nothing when Ford can slap a few more kwh in there. And I think that should be the preferred over discontenting and over skimping on efficiency.
pt19713
It'll come with a battery pack sizes of 90 or 108+ kWh. Based upon the dimensions of the car plus the large pack, it is probably not going to be a light vehicle, probably around 4900-5100 lbs. The aero will help but overall efficiency will drop just due to the weight, unfortunately.
Scarpia
US
Good thread, interesting. But...Mach E wins again? :rolleyes:
Yes but steady state highway range should be very good. The weight will reduce city range but should impact highway range less, where aerodynamics play a big role in range. If it has 108 kWh of usable capacity (I have not confirmed the number), it may have the best highway range on the market, possibly beating the Model S.
Excited
Norway
Mach-E RWD SR Techno+
GIS Engineering
just my opinion
Yup, and I'm expecting some software upgrades to make it a bit better...
Price vs range; MME looks pretty good, and if some think that range doesn't matter in Europe, o_O
The route they drive in the test doesn't have too much highway (110 km/h), but some. It has a good amount of elevation though, as the cars that has the longest range climb 1600 (altitude) meters. I believe most part of the route is driven at a speed of approx. 80 – 90 km/h.
You can see the test results at NAF's site here (Norwegian): https://nye.naf.no/elbil/bruke-elbil/test-rekkevidde-sommer-2021
I'm a bit disappointed that they didn't test the standard range MMEs. In the winter test NAF said that they wanted to test them, but Ford Norway didn't give them the opportunity :(
