Mach-e won't turn off
dml105
Arlington, VA
In the last two days, I've noticed my car not "turning off" when i leave it and walk away. The rear view mirrors close, so I know that the car is locked, but the brake lights and the headlines remain on. (Currently, it's been 10 minutes since I've left the car, and I still see the lights on through the windows in our detached garage.)
I've also noticed that when I reenter the car when it is like this, I get the "8-bit" Ford chimes instead of the Mach-e chimes, and the HVAC doesn't turn on automatically-- I have to manually press it.
What is going on? Anyone else experiencing this?
Paak is active, but I mostly use the fob.
Check your headlights switch. Maybe you have it set to On instead of Automatic?
Terry
Terry
Mustang Mach-e Black
This happened to me the other day, for some reason my headlights changed. I always keep it to auto, but they somehow were no longer in the auto mode. There actually wasn't anything that was lit up. I had to turn them to on and then back to auto.
peoples1234
NC
2021 Mach-E FE GB
This happened to me once. I just got in the car and rebooted it and switched the headlight switch to off. That seemed to fix it and it only happened once that I know of…
dml105
dml105
Arlington, VA
25 minutes in, it turned off when I hit the lock button on FordPass. The headlight setting hasn’t changed. (And that wouldn’t explain the 8-but chimes and lack of hvac.)
dml105
dml105
Arlington, VA
How do you reboot?
ten8bike
Bonnie
Marin County, CA
Ford F150 pickup
There is a setting to have the car automatically turn off in thirty minutes. Sorry I don't have the exact "route" to it now, but it is in the settings area of the car's computer.
kltye
IB MME Premium RWD
I'm not sure about the MME, but in my 2013 Fusion, the 8-bit chime was caused by a low-ish 12V battery voltage. I don't know when the MME engages the DC-DC converter to charge the 12V battery, but leaving the lights on for an extended amount of time might have drained the battery to have caused it.
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
Just got my Mach-E yesterday and encountered this.
My left knee must have bumped the dial (see image) and kept the headlights on. The car chimes constantly but I did not know what was wrong.
Ford Mustang Mach-E Mach-e won't turn off D5613721-9759-4D1B-B7ED-D98687B29FDB
Thankfully I didn’t leave the lights on overnight.
No, it's a bug. Changes by itself.
Kabish
2021 Mach-E Mustang
You did not bump it, welcome to owning a MME.
If you look at the knob you will see there is no orange indicator light. Just turn it till you see the indicator light and set it back on auto. That resolves the issue till it breaks again lol
AdamGilles12
Adam
Plymouth, Michigan
Ordered Mach E Premium All-Wheel Drive
Teacher/Coach
Had my MME for 5 days and this happened to me this morning when I auto started the car when it was in the garage. Not that big of an issue
WPJoe
Acura RDX
Also having this issue in my GTPE and I think its not a small issue.
The headlights stay on for a very long time - seems that the headlight switch resets itself off of Auto and then needs to be manually put back there...assuming you realize it.
In addition to draining battery, its pretty inconvenient for everyone around who is worried someone left their lights on and is trying to be helpful and let you know.
Maybe in the grand scheme of issues cars can have its not massive, but its actually quite inconvenient and noticeable and hopefully Ford is paying attention and can fix this.
@Ford Motor Company - that comment was for you!
Ford Motor Company
Official Ford Account
Good Morning! Would you send us a message with your VIN and dealership name and location? I'd like to look into your Mach E's headlight issue on my end.
