range
Dondan
MachEGT
Has anyone experience a reduction in range after the recall software update. Had the software updated for the connectors on my GT and after the first charge to my normal 90% saw a reduction of almost 35 miles. From 276 down to high 240’s. confronted my dealer thought it would get make to my normal range with additional charges. Hope so, i was very happy with the 270 plus range. any thoughts. thanks
dondan
Mathington
Canada
Mach-E Premium SR AWD
I would reset the settings for driver history on your car and see if that makes a difference after driving it for a week. It's possible that the dealership was testing the car and doing a lot of wide open throttle acceleration to see if everything was working okay.
More likely the update reset the history.
shutterbug
Joseph
AZ
That's true. After most recent update, my GOM went from 320 to 280. Previous update made it go from 340 to 280. In my case it take weeks for it to back to "normal", but I average 150-200 miles a week.
Dondan
MachEGT
Falcon53
Duke
Vancouver, WA
2021 Mach E GT, 2017 GT350
Pharmacy Software Development
dondan
I have seen same on my GT. 90% was 245 now 220. Dealer did update last week. one thing I noticed is when charging now my front air vents are open and close after it reaches 90%. Never saw that before. Also yesterday 7/20 I received OTA update 2.82. First OTA I have ever seen. Did do driver reset made no difference. Guess I will drive for a while and see what happens. Next item I need to figure out is the goofy charging pad with iPhone 12 Pro and why its so flaky. Works for a minute or two.
Dondan
MachEGT
Dondan
MachEGT
receive a tip that if i cleared driving history it might improve my range. Did that to my normal 90% and got the best range ever. 306. couldn’t believe it. try it it may help. thanks to the person with the tip
breeves002
St. Louis, MO
2021 Mach-E GT PE
Resetting the driving history doesn't improve your range. It changes what the range meter says. Your range would be exactly the same no matter if you reset that or not.
DaMeatMan
Toronto, ON, Canada
dondan
Just to be clear, "experiencing a reduction of range" and seeing a lower number displayed on the dash a two very very different things.
On the one hand you are actually driving somewhere and you actually get less range and can go no further because you depleted your battery.
On the other hand, you look at a number on the dash, travel no where and ASSUME that number translates into real world range, which it does not.
Sounds to me like the latter, and some driving history was erased with the update with that calculated GUESS'O meter now using some default values. But none of that has any real world bearing whatsoever on how far you can actually drive... it's just a number folks!
Dondan
MachEGT
Prior to the software update my range was around 275. After, it went to
Dondan
MachEGT
Prior to the software update my range was around 275. After, it went to 245, then 263 and the last after clearing history 306. If not clearing history then I have no idea why the improvement other then the update
breeves002
St. Louis, MO
2021 Mach-E GT PE
This is just the estimated on the GoM (guess-o-meter). This isn't actual range.... Reset your trip. Bet you don't get 306 miles.
Blue highway
Mach E Premium SR RWD
don't forget that the actual range of your car did not change at all... just the guessing algorithm.
