tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Latest version (1.2.3) stopped working for me. 1.2.2 worked fine.
Tried removing/replacing the script, removing/replacing the app, etc. I get these prompts. If I 'Save' the first I get the 2nd:
Sorry about all the issues... I'm trying to get time to debug this stuff...
SashaLondon
Sasha
London
MME AWD SR
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 3FA05740-A78C-4BF0-ACF9-BA1B3570DF6C
I get this message no matter what I do. I can see the widget in scriptable only. Any ideas?
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
Tried 1.2.4, script starts and I think the commands work (will try it later) but the widget isn't working
SAM
SAM
Central NJ
Premium MME4X Iconic Silver
I tried the beta version 1.2.4 that hopefully would fix the line 1814:23 error I and others had in v1.2.3. Got a can't find user error, so cleared the key chain but still no go. Here's the log. Sorry this isn't in GitHub but didn't open an account to make the comment.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) IMG_0905
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I'm sorry you guys are seeing so many issues.
I've been burning it at both ends lately and my quality is slipping. I'm going to do better testing before I release it.
I was able to duplicate the issues and will have a patch in the next 30 minutes.
kevC
Houston
2021 Mustang Mach-E AWD Preimum Carbon Gray
No worries man, you’re doing this out of the kindness of you heart, no one will complain. Take your time!
RMoore
Rob
@tonesto7, truly impressive work and generosity. I'm looking forward to actually getting my MME so I can try this. I continue to be amazed by the efforts on the part of several tech savvy folks with programming skills here on this forum who go out of their way to help the rest of us! I should also thank the many here with detailed knowledge of the car's inner workings who take the time to answer so many questions on this forum. I keep learning things here and my hats off to all of you!
SAM
SAM
Central NJ
No issue at all! I appreciate your efforts and the Widget is great. Just wish I could help more.
SoriceConsulting
Sal
NJ, USA
sorice.com
2023 GTPE, Rapid Red
IT Consultant
I've got the issues reported fixed. I'm just working on some minor tweaks to the widget layout to support better flow.
I know I said 30 minutes earlier but I need an hour or two more.
tonesto7, you're going above and beyond. Many thanks from me - and I'm sure many others as well, as already noted. As per my PM earlier, 1.2.4 is working for me. The only (minor) issue is that I am an Android user, so I'm using the widget on my iPad. But the widget screen is still pretty small considering the iPad (Air, 4th Gen) screen size.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) WidgetScreenshot
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Release v1.3.0
  • Modified the VIN field to store VIN as an uppercase string.
  • Added additional VIN format validations to setup prompt (Makes sure it's the right length and doesn't have any special characters).
  • Fixes and additional error handling for reported issues in the forums.
  • Modified the widget timestamp to reflect the last time the vehicle checked in and matches the last communication in the FordPass App (It's more descriptive now as well)
  • Added the ability to hardcode an id into the script to allow for multiple instances for multiple vehicles. See the SCRIPT_ID in the script header (Not fully tested).
  • Reworked the way all the window, door, and tire details are generated. They should now be laid out symmetrically.
  • Tire pressure numbers will change color based on different pressures states for low or critical. (see the widgetConfig.tirePressureThresholds parameter in the script header to define custom values)
  • Restructured the bottom of the widget to display events like low battery, deep sleep, firmware update, and any other errors. (It's also on a different line than the timestamp now).
  • Updated the widget generation logic to support the different iOS widget layouts [small, medium, large, extraLarge] (Actually layout changes coming soon).
  • Started working on the small widget layout working (needs a lot more work)
Download Link:
https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
Instructions:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
What's Next?
  • Slowing down on features and focusing on stability.
  • Working on small widget layout.
Community:
Discord: https://discord.gg/VPw3zw9v
SAM
SAM
Central NJ
Release v1.3.0
Download Link:
Instructions:
What's Next?
Community:
Thanks for the update. After running the script, I get the widget menu, choose show widget and medium. The widget shows in a window but after closing the window the widget does not show on the home screen. I can't figure out what's wrong.
