tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Thanks for the update. After running the script, I get the widget menu, choose show widget and medium. The widget shows in a window but after closing the window the widget does not show on the home screen. I can't figure out what's wrong.
I'm still trying to wrap my head around apple refresh logic of widgets.
Did the widget populate yet?
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Release v1.3.1
  • Fixed Oil Life showing no data.
  • Fixes for timestamp offset text at the bottom are offset too much.
  • Shows warning for Low Oil Life and low oil.
  • Fixed issue with advanced control menu going to wrong sections when only certain items were shown due to the vehicle capabilities.
  • Fixed the Alerts not allowed in widget error (this is really shown because the saved VIN is invalid)
  • Fixed repeated login prompt because of the deviceLanguage variable missing from the setUserPrefs call. Removed the requirement as it's not being used right now
Download Link:
https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
Instructions:
tonesto7/fordpass-scriptable: FordPass Widget for Scriptable (github.com)
What's Next?
  • Slowing down on features and focusing on stability.
  • Working on small widget layout.
Community:
Discord: https://discord.gg/VPw3zw9v
bs1055
Miami
2021 Mach-E Premium
Eng/M&A
Yes! The new update resolved the issue. Thanks so much for this — it’s awesome.
SAM
SAM
Central NJ
Premium MME4X Iconic Silver
No, unfortunately not. I updated to 1.3.1, runs well but still no widget on home screen. Tried deleting Scriptable app and its data on iCloud and reloading everything fresh. Tried "Clear all saved data" in Widget Settings. Same result each time, shows widget in window but not on home screen.
This may be a stupid question, but did you add the widget to your home screen?
I don't think the data timestamp is working quite right. It tracks perfectly with what FordPass displays for the first hour. But when the data surpasses 1 hour old, the time displayed in the widget resets and starts counting by the minute again.
For example, I unlocked my car 64 minutes ago. FordPass counted the minutes since it was last updated for the first hour and now just says "Updated 1 hour ago", which expected. The widget counted the minutes the same way for the first hour, but now says Updated 4 minutes ago.
SAM
SAM
Central NJ
Yeah, I looked for this in the customize widgets section, but not listed. But your question made me explore further. Did a long press on home screen and clicked + in upper left and scrolled to Scriptable app and selected it. Got a generic medium sized Scriptable widget to show on home screen. Then had to click on widget to select the Scriptable FordPass script to run.
Worked. Didn't have to go though all that last time.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Do me a favor and tap on the widget to bring up the menu > go to widget settings > Debug Menu > View Vehicle Data Output and look for lastRefresh
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 1639924630449
The time and date are in the UTC timezone
Last Refresh shows "12-19-2021 14:14:14", which is about 30 minutes ago in EST and the widget shows that it was updated 30 minutes ago. But FordPass says that it was updated 2 hours ago.
SoriceConsulting
Sal
NJ, USA
sorice.com
2023 GTPE, Rapid Red
IT Consultant
Working well for me, except for (as mentioned in an earlier comment) that the widget does not scale up on an iPad screen. Still tiny. Also, I thought there was a mention about showing one decimal place for the battery voltage (like 12.5 instead of just 12). I think that would be important to know.
Well, those steps are included in the instructions :)
Also, for anyone still copying/pasting the script every time there's an update, I recommend you follow @tonesto7 's note about saving the script file to iCloud. Overwriting the file there is easier than copying and pasting since Safari doesn't natively support Select All.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
FYI - i've decided to make this a christmas project for myself to migrate this to android (and maybe windows). Hope @tonesto7 is cool with that and I will definitely open source as well once it's ready :)
I would really like to be part of it. I haven’t really had a reason to develop anything for android yet. I have a few android devices. And lots of dev experience in Java and html
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I'm more inclined to think that the FP app is not updating the time elapsed.
the script is working with the data it has available which is the same exact data used by the FP app
It's weird that it's spot on with FP app and suddenly they skew
