Strange Blue bar while using NAV
Cruise is off, front space detector is active and you're ok. It turns colors (red is high alert) when someone is in that space while you're driving.
DaveQ
Fernandina Beach, FL
Mach-E4X, HR-V, Insight, Maserati Levante S
How do I get speedometer back in the middle, do I turn off front space detector in settings?
JCHLi
I just assumed the bar was showing I needed to be in the right most lane for the turn.
I'll keep watching and see if this theory holds.
Tsand4
Todd
WMich
Mach E 1st Ed -rec'd 1/27/21, '14 Fusion Hybrid SE
I have noticed the blue bar as well, but have not determined the purpose based on time of occurrence.
On another note, I have also had voice command pop up randomly and wondered if others are having this. I could be inadvertently hitting the button, but I doubt it.
I saw that bar 2 times today while using NAV. In both cases, the bar appeared on the right and preceded a junction in the road. Once I passed the junction, then the bar disappeared. First instance was a left turn. Second was a right turn.
I use Nav often......will pay more attention during my route to see if I can figure out a pattern.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Mine flashes constantly going 75 on our turnpike here. No junctions, no turns coming up, just open road.
It must be confused for some reason.
Nearing the end of day 3 and just over 500 miles. Used nav several times. Saw the blue bar many times. In every case, I was on the freeway and exactly 1/2 mile before a junction from one freeway to the next the blue bar would appear. Bar always appears on the right no matter which way I am going. The bar also appears when my exit/offramp was approaching....again exactly at the 1/2 mile point. I never saw the bar on surface streets.
I think the bar is there (along with the associated chime) to alert the driver that a junction is coming up so we can make sure we move into the correct lane. Something that is especially useful because when using ACC (Adaptive Cruise Control) and LKA (Lane Keeping Assist) because it is easy to lose track of the exact route and possibly miss the junction.
JellyBelly
Kris
MME RR FE
I have seen the bar too... they need to add an explanation for it.
At the same time the bar appears, there is also a more detailed graphic on the SYNC screen that shows the specific lanes you should be in for the upcoming junction. I agree there should be more detail provided with the blue bar. They could put some text in there that causes you to check the SYNC screen or something similar.....
GoGoGadgetMachE
this is probably pushing my luck but I'd argue that if they are going to put text in there they should just put the lane guidance there and be done with it. That would be a lot more useful than a bar with text.
JellyBelly
Kris
MME RR FE
It’s small bar so text May not be feasible. But they should at least explain in a manual what that bar means...so far I have not found a sync 4a manual ... yes there are bits and pieces of settings info in the user manual but not enough to explain everything we see if we are required to interpret and act upon. Simple stuff like how do I reduce brightness of the main screen... not explained anywhere.
JamieGeek
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Update:
I've now also seen the blue bar on the right (in the same location as the image I posted to start this thread) while the nav was indicating a left turn. Thus it isn't indicating a lane change or a turn coming up. Its just some display artifact.
