- Sep 5, 2021
- Florida
- 69 Mach 1, 11 GT, 21 GTPE- sold, 24 Taycan 4S, 20 F type R
I definitely didn’t fill in all the details (didn’t want to write a full book, that’s what the discussion would be for).I think you're missing a whole lot of stuff in your OP.
If you cruise along at higher speeds you'll have some jail bars. We've always known this. But it's just a handful of them, not 10, 15 or whatever, it's closer to 3-4.
When you go under those per-determined speeds the jail bars immediately fall off. This would indicate 100%, that those jail bars are speed based. Again however, that's just a couple of them.
If you accelerate full throttle for 5 seconds you get a crap ton of jail bars. Surely some of them are from the speed thresholds, but the rest are from the 5 second limit. This is also proven in that the ones from the 5 second limit will NOT drop off once you go under those per-determined speeds until things cool down. While you can't see my speed in this video, you can hear the rumble strip and you can tell that I still have jail bars well under 50mph.
So, in summary, yes there's a 5 second limit and yes there's per-determined jail bars at various speeds, what we see when we accelerate 0-80mph is a combination of them both. Not to mention there's jail bars for low SOC, cold weather and probably a few other things.
^^^^.............5 Second limiting
.............^^.......Speed limiting
But yup, you helped cover some of the other details for sure.
The amount of jail bars for sure comes from the other factors including-
Speed- 72 mph
State of charge
Battery temp
External temp
And by far the BIGGEST limiter- discharge rate over time.
The more power you use in a shorter time period, the more jail bars you get.
But to the entire point of the thread- none of these are some 5 second timer counting down.
This is both confusing and different. Because our competitors (Kia, Hyundai for example) use a 10 second timer.
